20 Most Recent
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Questions & Answers
With Sony KP-46WT520 46 in. Rear Projection
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Sony kp-fs53m91 standby blinks fixya
Dear Sir,Please advise us how to removed video white linefrom Main Screen of the Sony Model Number(KP FS53m91) with complete Descriptionkind regardsSaddique Akbar
No sound, no picture but timer srandby light is
If the stnadby light blinks 9x, there is a leaky diode in the G board(5Volts standby circuit) causing the problem. I don't have the service manual but I remember it's the D6301. To make it sure check all 8 diodes including the one in zero detection circuit(all in G board). Hope this helps :)
TV won't turn on, standby light just blinks 9times
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
At times picture is redish and scrambled
The next time it does that go to the Convergence menu in the main menu and look to see if convergence is bad when it looks scrambled.let me know what you find.
