20 Most Recent
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Questions & Answers
I recently replaced the 2100U lamp in my kf50we655
The problem is the light engine, the coded lens blue filter is burned out. It can't be cleaned. You may search on Google or EBay to find a replacement engine, it usually cost $400.00 to $600.00 to get one.
Is my Sony Grand Wega Consumer Electronics Control (CEC) compatible?
What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions?
Submit a request
Related articles
How do you replace the ballast on a kdf e55a20
to change a ballast board its a bit of work and a tear down to get it in there . but first lets review your problem .
its cycling off every 30 seconds . id suspect a defective lamp or a power supply problem since it sounds as if the ballast board does fire . that's assuming that you do see something come up on the screen when it attempts to start if a ballast has failed it usually will make a noise or the set would almost go into a shut down . also how many blinks and what order are the events happening ?
