Trendware TRENDnet TE100-P1U Print Server won't
OK, are you doing all this as Administrator? This is a must do.
Are you sure that you have the right IP address?
Can you Ping the unit?
Try another browser to do so, try Firefox, or Google Chrome.
Is your Ethernet cable OK?
Is the Driver a Win 7? if not perhaps you need to set compatibility mode for XP SP2? AND Run as Administrator.
Is UAC set to OFF.
If 64 Bit system has Digital Driver Signing been set to OFF, if the driver isn't digitally signed? (Press F8 at boot up and choose from bottom of list)
Also make sure that you have Disabled DHCP server in ALL PC's, go to Services, and see if it is disabled? It needs to be.
Below is the install how to, have a look at it, see if it's the same as yours?
downloads.trendnet.com/TE100-P1U.../Manual/QIG_TE100-P1U(english).pdf
OK, try this hook directly to the PS, from a PC via, use an standard Ethernet cable, use a direct connection, Do NOT go through the router/ switch, now try setting it all up. Now you should see it connect to the unit,
You should be able to access it, if direct connected, if it still doesn't respond, then the only thing it can now be is a faulty unit?
If OK, once configured then you can hook it up as per diagram, and it should then work.
3/10/2013 12:27:53 AM •
Trendware...
Answered
on Mar 10, 2013
