20 Most Recent Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape Questions & Answers
2answers
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
7/2/2019 7:53:35 PM • Sony Betacam SP... • Answered on Jul 02, 2019
UVW-1400A A tape got caught in
Contact sony for listing of repair places in or around your zip code.
9/19/2017 2:09:40 PM • Sony Betacam SP... • Answered on Sep 19, 2017
3answers
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
6/4/2013 12:25:20 PM • Sony Betacam SP... • Answered on Jun 04, 2013
0answers
0answers
3answers
Error 02-603
Yeah, unscrew the 2 top screws. Underneath the lid, there's instructions on how to manually remove the tape. You're also going to have to pull out the tape tray. There's a metal piece holding it down that you can remove by taking out the 2 screws. Then it's a matter of pulling the tray out and turning the tiny gear at the front (not the 2 bigger ones on the side) until it makes the full motion path. Holy ****, that takes a long time. Once you have removed the tape, replace the tray, the holding bar, the 2 screws for that, and the cover.
9/9/2010 6:17:50 PM • Sony Betacam SP... • Answered on Sep 09, 2010
Sony bvw300 humidity error
Use an hair dryer and warm within the set. If it clears wipe off any dew that has set in . Wipe also the head clear with a good swab. if the fault is recurring then clean the dew switch sensor or replace.
This is found inside the loading compartment , a small square block. about 1.5mm. Helpful. Good day
7/14/2010 12:44:09 PM • Sony Betacam SP... • Answered on Jul 14, 2010
0answers
3answers
Error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
12/11/2009 5:13:37 PM • Sony Betacam SP... • Answered on Dec 11, 2009
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
8/26/2009 3:28:31 PM • Sony Betacam SP... • Answered on Aug 26, 2009
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
7/16/2009 4:25:51 PM • Sony Betacam SP... • Answered on Jul 16, 2009
Electronics - Others Logo
38 questions posted
Top Sony Electronics - Others Experts
Sean Wright
Sean Wright
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Electronics - Others
Most Popular Question
error 02 603
  • Electronics - Others
