20 Most Recent U-Line Refrigerator Ice Maker Questions & Answers
the condensate drain pump will shut unit down and only run drain pump if over fill is seen may be noise you are hearing
if condensate pump removed has to be wired so kill switch in drain pump is over ridden for gravity drain
U-Line... | Answered on Nov 15, 2017
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
U-Line... | Answered on Sep 07, 2017
Follow the water line to the water connection from the water supply from the home. The valve should have two wires connected to it and will likely be behind a removable panel.
U-Line... | Answered on Dec 06, 2014
You could have a stuck closed water control valve, timer issue or the tray full lever/bail is in the up position.
An appliance parts supplier might have one or be able to get one.
U-Line... | Answered on Jun 10, 2014
Hard to say but I would start by checking the thermostat.
U-Line... | Answered on May 12, 2014
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
U-Line... | Answered on Apr 23, 2014
Model 88058 Honeywell Wine cooler, my mistake, the capacitor in the upper LEFT corner had bulging rupture disc groves, replaced, with higher voltage, about $1.50, now works great
U-Line... | Answered on Jan 18, 2014
HAVE YOU FIXED THE PROBLEM?? i WAS JUST GIVIN THE SAME WINE COOLER WITHT HE SAME PROBLEM
Check for 120 V at valve when it is supposed to be filling
U-Line... | Answered on Nov 22, 2013
If you pull the cover off the front of the ice maker you will see a little screw in the upper right corner it will have a + and - screw clockwise to the -
Possible water valve needs replaced check to see if you have water up to the valve
go online to www.searsparts.com and put in your model they might have it there
It could be the solenoid where your water line comes in from the wall and sends it up to the freezer. Follow your water line to the bottom of the frige it could either be in the back or the front. Might try looking under the fridge to see if you can see it that way.
U-Line... | Answered on Sep 17, 2013
U-Line Refrigerator Ice Maker Logo
122 questions posted
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
u line co75fb under counter
  • Refrigerators
