20 Most Recent
U-Line 2075DWRR Compact Refrigerator Questions & Answers
Model# U-C02175DWRS Refrigerator warm, freezer
Hi debrashaver,
If you're experiencing continuous beep, that is an alarm for the door being open. Please check the reed switch on the wall and the magnet on the door. For the top drawer, it is located at the upper left. and on the bottom it is located on the grill and door. This is the easiest way to correct the beeping issue.
Just let me know that will happen next.
Hope it helps.
Thank you for using FixYa.
The alert notification is from a u-line refrigerator and beeps even when door fully closed
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
6/1/2018 4:50:59 AM •
U-Line...
Answered
on Jun 01, 2018
