20 Most Recent
Sony CDP-CX400 400-Disc CD Changer Questions & Answers
My Sony 400 cd player will not play any cd's.
Your optics are either Really Dirty, or out of line and you would need a replacement optic pickup. If you are mechanically inclined, it's not a difficult repair and parts can be purchased thru lots of sites. First things first, pop the top and use "Dust-OFF" in the main chasis, it gets bad! Next, if you have a good CD/DVD player cleaner that uses fluid, run it thru a couple times then test any disc. If you don't have one, just about any convenience store has them. Just make sure it uses fluid!. If you still have an issue. post a comment and I can pdf you the schematic of the unit. it's pretty easy to read and follow if your a little more than a novice with electronics. Hope this helps
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
