20 Most Recent
Meade TeleStar 60AZ-A Telescope Questions & Answers
Meade telestar D=130 mm F=1020 mm
rosores: make sure that the DEC clutch is not locked, and that the screw on the side bar is loose.
before pointing it upwards. or damage may occur.
STH55
I need to find a
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
BI need to replace some
You can buy eyepieces from many on-line retailers. Eyepieces come in 3 sizes .965, 1.25 and 2 inch sizes. The .965 size is harder to find. Measure the HOLE in the focuser or the diagonal and buy the correct size.
Here is one on-line retailer that sells eyepieces:
http://www.agenaastro.com/
I need to find an Eyepiece for my grandsons
Most telescopes use a standard size for eyepieces (one and a quarter inches outside diameter) and if that is the size of the mount in your scope, you can use any that fit. If you do a search on Amazon, you will find hundreds in this size, many of them branded Meade. The other dimension specified will be focal length. 5mm will give high magnification (but dimmer and harder to use) while 20mm will give lower magnification with brighter image and less fiddly focus.
Just set it up and it picks up no objects
This is a small REFRACTOR style telescope of 60mm. Not much larger than a pair of 10x50mm binoculars.
Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x or 3x barlow if you have one. Practice focusing on a distant object during the day time. The moon should be your first object at night.
Read my TIPS on my profile page and read this:
http://www.texasastro.org/telescope.php
The viewfinder is not acculimented with the
Point the scope to a distant object like the top of a telephone pole.
Without moving the telescope adjust the small screws on the finder scope to LINE-UP on the same object.
When i look through th eye piece i dont see
If you have a refractor style telescope like the picture, put the diagonal into the scope, DO NOT USE the 2x barlow if you have one.
Then put the eyepiece with the largest number written on it into the diagonal. Go outside during the day and practice focusing on a distant object.
