20 Most Recent
Philips DVP320 DVD Player Questions & Answers
Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Can you please supply the
Try the following instructions:
Turn on the DVD player without a DVD inside.
Open the lid.
While the lid is open, press 9-9-9-9-0.
You should now see REGION 0 displayed.
Then just close the lid.
Your machine should now be region free.
Programming note:
For single custom region just replace the 0 with the region number desired (1 to 6).
If this was at all helpful please click on the 4 Thumbs Up rating icon.
Thank you very much.
Srtill no luck with help
Please try the following procedure: start the player without any disk on it, open the disk tray, leave this way and at your remote control press 9 9 9 9 0 , you should see region 0 displayed, then close the disk tray, your player should be now region free.
Hello again. Have not as yet managed to solve my
Try this:
MAKE SURE THERE IS NO DISC IN THE UNIT
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number ("0" for region free).
It s posible divx in this dvd player?
The short answer is NO it will not play Divx. It will only play DVD, DVD-R/RW, DVD+R/RW, VCD, SVCD, CD, CD-R/RW, or MP3-CD.
I hope this helps and good luck!
I do not get color on the TV
If you are using the S-Video output, please try a different cable or first re-seat the connections at both ends.
Good luck
Dvd player gives unknown disc
thats because its region locked..do the following:
open the lid.
close the lid.
note:
do let me know if it worked.
Remote Control for Philips DVP 320 DVD Player.
I guess, the easiest way to go is to get an universal remote control and try codes from the provided list until you run into a working one. Many universal remotes have a mode when you can try to click tens or hundreds time on a button (like UP button) until it accepts the code.
