20 Most Recent Philips TS2746C TV Questions & Answers
Go to the manufacturer's website, which in this case is Phillips.. Large companies such as this will usually have an owner's manual available for their product's in pdf form so you can read it on your computer.
Philips TS2746C... | Answered on Aug 03, 2014
I need more channels. I ONLY get 13 channels, 1-13. I know im supposed to have more... Phillips Consumer electronis: manufacture no# 3210t127a
Philips TS2746C... | Answered on Feb 20, 2009
you better replace the memory IC with 8 pins 24COxxx,near the system IC.
hope it may helps;
regards
Philips TS2746C... | Answered on Sep 07, 2008
I did not answer the original question you posed but the SAP is the acronym for Separate Audio Program and is used to provide spanish for instance on a show which is broadcast in both english and spanish. The problem is not all stations have audio on the SAP. If your audio processor is set to SAP and you switch to a channel which has nothing on SAP you loose audio. I'm guessing someone suggested this prior to this post. If you checked your TV and it is not on SAP that eliminates that. I would look at the audio circuit for problems. Either no power to the audion circuit, bad solder joints, blown output IC or possibly a blown speaker. I know the last one is remote but it does happen and it never hurts to check the simple problems first. Besides you aren't embarrassed later when you find out it was something simple. If you are going to check these issues out remember safety. Good luck.
Philips TS2746C... | Answered on Jun 23, 2006
https://translate.google.com/translate?sl=auto&tl=es&u=https%3A%2F%2Ffactory-reset.com%2Fwiki%2FPhilips_Service_Menu
Cuidado cambiando algo que puede ruinarlo completamente.
https://www.usa.philips.com/c-p/55PFL5706_F7/140cm-55-inch-class-full-hd-1080p-digital-tv/support/
Empuja Online chat para chatear en ingles.
Philips... | Answered on Dec 04, 2019
ASK GOOGLE I HAVE NO CLUE WHAT YOU WANT WITH YOUR POOR SPELLING
Philips... | Answered on Nov 29, 2019
Ring manufacturer and ask for code. Sylvania ??? hmmm
Philips... | Answered on Nov 25, 2019
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
Philips... | Answered on Nov 22, 2019
With a video cable.
Do you have a question? Then tell us what model of TV and what device you are trying to connect to it.
Philips... | Answered on Nov 21, 2019
it could be defective lamps which are big project to find the right parts & replace
Philips... | Answered on Nov 14, 2019
the dvd are not from your country region thats what it means to retify re burn the dvds to your country region code or buy a multi region code dvd player
Philips... | Answered on Nov 07, 2019
Philips TS2746C TV Logo
9 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
more channels channel set up phillips
  • Televison & Video
