20 Most Recent
Philips Magnavox 20MS233S 20" TV Questions & Answers
TV will respond to remote control
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Codes for magnabox
0038,0031,0025,0020.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list
& set-up procedure to many popular brand remote controls.
Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
How do I shut off
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
20ms233s tivo remote code
Try one of these (remote code) numbers to connect your remote to your Magnavox TV : 00051, 00054, 00802, 01198, 01254, 01365, 01454, 01856, 01866, or 02372
M3250 no power on
Check and replace damaged component/s at its main power regulator section circuit.
Lost access code number
If you means that you did forget the universal remote codes, these are the codes for Maganavox TV: 0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can
be selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. Some times, the ads
attached with each posts, both at the right and bottom, might help you to find
the availability of spare parts. There
are more than 750 posts to different brand TVs now.
My remote control doesnt work
Check the remote control for its infrared emission. To get more details about how to check the remote control and to repair it if it found faulty, Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help. Pull up older posts there. Fault finding to remote controls and repair proceedings are given here in detail.
