20 Most Recent
E-Machines eMonster 550 PC Desktop Questions & Answers
Beeping noise after installed memory on ecs motherboard L4S5MG
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
No pic on monitor
Please double check, you should have two cables out of the monitor and connected.
1. The power cable to your UPS/ AC switch.
2. display cable connected to the CPU(main box).
Based on the information you gave one or both of these cables are not connected/switched on.
Thanks.
Monitor screen while booting says out of range
while booting into the Operating system try pressing F8. It will take you to the os menu and select VGA loging in mode in that. Later after entering the operating system reduce your monitor resolution say 800 * 600 it should fix the problem.
I have an eView 17f3 computer monitor that was
well that is 17,000 volts there 17kv and can be lethal .
CRT is cathode ray tube and 2nd anode is 17kv, 1kv per inch screen.. we use a chicken stick to discharge that.
one guy gut hit here and flew across the room ,hit head and next up paramedics deep.. not fun to see that. ive taking 600v but never again.
vaccum seal, why do that.???
send it to the , toxic lead recycle center, let them do the danger work
when I was only 16yo I worked in TV shop and I had do that "nnipp" that in the bud on all CRT sent off to refurb. (or toxic trash) (we sold them all here, you name it)
we had to remove the socket there find he glass bud there dead center and full PPE, and snap it with wire cutters and it sucks in air fast. later in military too on old radar scopes, i worked .
the vacuum inside is pure and prefect, zero gasses.
implosion hazard exists. a glass flies in the bounces out and hits you and then next up blind i one eye. leave CRT alone to the trained.
Hi i have emachine 8230 tower
firstly lets think why a Working pc would no longer BOOT. The boot process then. a pc starts the bios which POST's. this results in ONE BEEP which might be followed by messages(if you get several beeps then they are like morse code long/short and count out an error code). when you get your ONE BEEP the pc is working. when it then HANGS(appears to do nothing) its usually because of either a) the cd drive is duff so disconnect its cables. b) the hard drive is duff so disconnect its cables c) the hard drive hasnt quite died yet but has some very slow sectors and is making the Clackety Clack of the heads recalibrating every few seconds. d) there could be a a gpu card bios glitch and your pc is running but you just have a blank screen. some hints then 1) never start removing parts as that corrupts the CMOS(the battery backed up configuration for your BIOS) so you may need to clear your cmos. 2) never play with the idea of changing ram sticks as people usually end up putting them in any old slot(which may result in a non working pc). make sure a PAIR is fitted in slots 0/2 and a separate matching pair in 1/3 slots not in slots 0/1 which is two half pairs. Other factors. 1) a short circuit. your PSU has built in protection, if the psu fan(inside case of the psu) turns and kicks back and immediately stops you have a short circuit and its cuts the power to avoid a fire/meltdown, which could be caused by high wattage gpu(>60 watts) without its extra power cables fitted or wrongly connected front usb cables or removing a mainboard and fitting it into a new box where the board has its support posts NOT lined up with the holes fro the screws so the post is touching underside of the board circuits. hope some of that helps.
Emachines 3240 - cannot recover
Download a Linux distro to a flash drive or DVD and see how well it runs off that. There's HDD utilities like SuperGrubDisk that can diagnose things.
E machines model et1831 will not boot up
try booting to safe mode. by using f8if that works, try a system restore to a previous date. if that does not help, then it must be a windows corruption and parallel install or repair install will be needed, it can also be fixed by manual troubleshooting and repairing the files.
