20 Most Recent
Sharper Image 10x28 Motorized Focus Binocular (BI119) Questions & Answers
I bought the 10x25 camera
It is common for binoculars to have one independently focusable eyepiece. If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side. Then rotate the eyepiece on the blurry side until the blurry side is sharp. If you succeed at this, from henceforth the center control will focus both eyes adequately
I have a mac and the cd that came with the
Hello.
You have to have a cd software that is supported by mac.
You can check from the official website of the brand and see if there's any drivers or cd available for Mac.
I am seeing a double image whel I look through my binocular.
Most binoculars should allow you to grip the two sides and pull them closer together to fit the distance between your eyes.. Have you tried this?
What you should see is the two images come together to form one.
If you have tried this already and you still get the two images then it's possible the model is just too wide for your eyes.. If they're new you could try return them for another type that fit better..
If this works for you then here are the instructions for setting up the binoculars to give you the best result for your eyesight..
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Lost the usb cord need new one
You should be able to pick a new usb cable up from any electronics store like Radio Shack. Take the binoculars with you and they can match up a cable for them. Simple as that. Let me know how this turns out.
Benjamin
What type of USB cable does these
Well, there are standard USB A and B, mini A and B and micro A and B that are recognized as industry standards. Then there are proprietary designs used by one manufacturer. Sharper Image went into bankruptcy and I assume the brand was sold off. So without a model number its impossible to determine who made the item for the seller.
