20 Most Recent Sharper Image BI114BLU Binocular Questions & Answers
2answers
What kind of USB cable comes with Sharper Image 10x25 binoculars
Go onto the www.Sharperimage.com web site if you look it will tell you that Sharperimage are in receivership but they do point you in the direction of a support comapny called N.E.W.
In reality you should be able to buy those leads from any decent camera shop or a place like Tandy
12/14/2018 8:34:52 AM • Sharper Image... • Answered on Dec 14, 2018
0answers
2answers
I bought the 10x25 camera
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
2/27/2011 1:27:49 AM • Sharper Image... • Answered on Feb 27, 2011
2answers
Sharper Image Digital 10 x 25 Camera Binocular NEED DEVICE DRIVER
Try This website:
http://www.mscustomercare.com/
11/30/2010 4:34:59 PM • Sharper Image... • Answered on Nov 30, 2010
I have a mac and the cd that came with the
Hello.
You have to have a cd software that is supported by mac.
You can check from the official website of the brand and see if there's any drivers or cd available for Mac.
10/23/2010 1:06:23 AM • Sharper Image... • Answered on Oct 23, 2010
Need to replace an eye cup for sharper image
An eyecup doesn't change the image sharpness. Have you lost one and need a replacement?
3/3/2010 12:06:11 AM • Sharper Image... • Answered on Mar 03, 2010
You put the wrong size usb connector in the camera
I just took 60 photos with my new x-mas gift. But, I can't download them because THEY INCLUDED THE WRONG USB CABLE! The jack doesn't fit the camera port.
12/25/2009 5:52:03 PM • Sharper Image... • Answered on Dec 25, 2009
I am seeing a double image whel I look through my binocular.
Most binoculars should allow you to grip the two sides and pull them closer together to fit the distance between your eyes.. Have you tried this?
What you should see is the two images come together to form one.
If you have tried this already and you still get the two images then it's possible the model is just too wide for your eyes.. If they're new you could try return them for another type that fit better..
If this works for you then here are the instructions for setting up the binoculars to give you the best result for your eyesight..
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
10/21/2009 11:24:40 AM • Sharper Image... • Answered on Oct 21, 2009
Lost the usb cord need new one
You should be able to pick a new usb cable up from any electronics store like Radio Shack. Take the binoculars with you and they can match up a cable for them. Simple as that. Let me know how this turns out.
Benjamin
7/29/2009 1:23:12 AM • Sharper Image... • Answered on Jul 29, 2009
What type of USB cable does these
Well, there are standard USB A and B, mini A and B and micro A and B that are recognized as industry standards. Then there are proprietary designs used by one manufacturer. Sharper Image went into bankruptcy and I assume the brand was sold off. So without a model number its impossible to determine who made the item for the seller.
6/17/2009 12:19:15 PM • Sharper Image... • Answered on Jun 17, 2009
3answers
How do I change Language on a sokkia set 250x total station
hi deshwashin error vod d13 brandt thnks
4/4/2024 7:00:30 AM • Optics • Answered on Apr 04, 2024
Need manual for edu science star tracker telescope
Yes I do
1/13/2024 1:28:24 PM • Optics • Answered on Jan 13, 2024
Tascos riflescope 3x9x50 adjutment caps
Visit your local gun shop and have them order them.
10/17/2023 10:13:50 PM • Optics • Answered on Oct 17, 2023
I need firing order for a 1981 Johnson seahorse 115
its just 1-2-3-4- with the port bank being 2-4 starting at the top and the starboard side being 1-3. They're all the same be it V-4 or V-6. 6=123456 60* and 90* are the same
5/31/2023 9:13:49 PM • Optics • Answered on May 31, 2023
Sharper Image BI114BLU Binocular Logo
0 questions posted
Top Sharper Image Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Sharper Image Optic Expert? Answer questions, earn points and help others
View Most Popular
  • Sharper Image Optics
Most Popular Question
am seeing double image whel look
  • Optics
