20 Most Recent
Sanyo DS27910 27" TV Questions & Answers
I have a Sanyo ds19350 tv. It sometimes suddenly
High voltage failure. Take off the back cover and look for the high voltage transformer. The transformer has high voltage at about 380 volts with low current, but it will give you a shock. Usually, there is a capacitor or two, hopefully, there is only one capacitor. Check the DC voltage across it - should be about 390 to 400 volts. If not, change this high voltage capacitor. Buy one bigger than the current one by three times.
I have a Sanyo DS27910
You can purchase the original remote for $20.99 base price.
http://www.replacementremotes.com/SANYO/Buy-FXRG-6450459313-TV-Remote-Control.html
My sanyo was working fine, then a child hit a
The TV has different inputs modes, the TV tuner being on of them, another mode(s) will accept an input from the input jack(s) on the back, front or side of your TV. Look for and source button or input button on the front of the TV, press it waiting a few seconds between each push until the picture returns.
The fuse is blown,what can be the problem?
Hi derrick
i`m going to help you with your tv but first;
Did you try and replace the fuse?
Sometimes the fuse will blow after a power surge or black out.
And could you give me your tv`s brand name and model number so i can assist you further ?
RE:Sanyo 27 " Flat Tube Set
What about a cap in the power supply for the
vertical circuit? Usually found near flyback--
2)check vertical drive signal (comes from jungle IC ).Use your scope....
