20 Most Recent
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Questions & Answers
Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Thethe tv will not come on and power and theopc is
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Loss of picture on LCD TV when first turned on. Must restart.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sharp tv remote control problem
Keep your mobile camera on press any key from remote you will get flash light in mobile.It means remote is ok.
Press On/Off switch from LED Tv and checked tv is on or off.
If Green light is blinking but tv not getting on follow as per attached file.
Sharp Aquos LC-26D4U sound problem
GOOD NEWS - - According to the Sharp Technician I just spoke with a "Service Bulletin" went out to all their techs about the sound issue on these Sharp Aquos. I'm having the exact same sound probem and I'm in the process of having the technician come out at no charge so call the number given in Solution #6 and #9 (1-800-237-4277) and keep pressing #1 until you get a technician. Have your serial number ready and they will need your name, address and telephone #. They will then give you a case number and transfer you to dispatch (which closes at 5pm central). Thanks everyone for your help and posts - you made our day!!!
BTW - We also have the problem of the TV turning on and off by itself but the technician said they had not received a service bulletin about that yet.
TURN TV ON JUST PLAIN
Do you see the backlight ever coming to the screen?You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.If it does it's the inverter.if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.A good tech should be able to test the power board independantly fairly quickly.
Power not working on sharp aquos tv
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Just recently my sharp aquos
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
