20 Most Recent Sharp Aquos LC-37HV4U 37 in. LCD HDTV Questions & Answers
Hi. I need the 4 screws to mount the TV stand to
They are metric screws, you van get them at Lowe or HD, try M5 or M6. they are about 35cent each so you can try difference length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
6/19/2019 6:41:27 PM • Sharp Aquos... • Answered on Jun 19, 2019
2answers
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
12/27/2018 4:08:50 AM • Sharp Aquos... • Answered on Dec 27, 2018
Is there software for lc-37hv4u
Go to Sharps web site to get software updates. Load the file on a USB stick and follow the instructins on how to install the file to the TV.
12/31/2014 2:50:05 AM • Sharp Aquos... • Answered on Dec 31, 2014
Internal or external speaker selection does not show
Do a factory reset to this set. To do it, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given.
3/21/2014 6:06:54 AM • Sharp Aquos... • Answered on Mar 21, 2014
0answers
Avc if avail
Be the first to answer 2/4/2014 5:20:31 AM • Sharp Aquos... • Posted on Feb 04, 2014Be the first to answer
0answers
0answers
Sharp Aquos LC-C32344 Manual
SHARP 65 LC65D90U 1080P HD LCD TV
I like this a product very much
muchhttp://www.eboyvip.com/goods.php?id=646
9/6/2013 3:53:42 PM • Sharp Aquos... • Answered on Sep 06, 2013
0answers
2answers
Screen will not turn on. red light flashes. all
HAHAHA I will tell you for free...geeeezzzz....(but you could rate me though;) )
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! 37df1db.jpg
7/4/2012 4:45:17 PM • Sharp Aquos... • Answered on Jul 04, 2012
0answers
4answers
This is the problem with my LC-37HV4U. I plug in the AVC and the tv/monitor and I get both red power lights (not blinking) but no green lights, sound, or picture. I mean the tv screen stays black! It seems like their is no communication between the AVC and the monitor. I thought at least the screen would light up when the power light came on and being it has it's own power source. This tv is driving me nuts!! Can anyone please help?? Thank you.
5/8/2012 10:57:23 PM • Sharp Aquos... • Answered on May 08, 2012
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
76 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
need 4 screws mount tv stand
  • Televison & Video
