20 Most Recent
Westinghouse LVM-37w1 37 in. HD-Ready LCD Television Questions & Answers
Does a westinghouse play mkv
After busy work, turning on the computer or TV and watching a movie comfortably is a way for many people to relax. Sometimes when we have downloaded a movie and are ready to open it with a player on a TV or computer, we find that these devices or players do not support some certain video encoding standards, such as H.265. This seriously affected our mood at the time. So, these best
H.265 to H.264 converter
come to help solve this problem.
Remote wont work
Check the battery if its good.First see your remote is sending an infra red out to TV.When you press the remote button look through a digital camera. If you see a light coming out of the LED it means remote is transmitting a signal.
LVM-37w1 after 5 minutes of viewing, picture and
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.
After about 10 min. screen goes blank like power
You might want to check the sleep timer, it may be ON and set for 10 min. Go to the OnScreen Menu to get to this setting. Also, you could be nearing the end of your "relationship". There may be an internal board problem that may mean a trip to the TV doctor.
New 37 in. tv conn. to cable not hdtv i have
According to all the tech sheets I can see, this unit has no Tuner. If your using the cable box to change channels it probably doesn't support HDTV, except maybe for the individual channels. You might be able to access your TV's on-screen menu to change the way programs are displayed.
Picture turns off after 1 second. Power supply
morrfl, All lcd tv's (plasma & fluorescent lamp backlighted) have "smart" power supplys (ac line to dc) that are called "switch-mode-power-supplys" that can detect FAULTS with other circuits or with themselves and will go into what is known as SHUTDOWN-MODE when a FAULT CONDITION is detected. The SMPS does this to protect against having a catastrophic nonrecoverable failure! e.g. sparks, smoke, fire. There are many reasons that LCD tv's go into shutdown! However, your set is a viable candidate for repair. When you stated "picture turns off after 1 second" means it still has the capability of displaying information on the LCD panel! But don't do anything just yet about fixing it. Check the availibility of a replacement SMPS number DPS-336AP. The drop-in SMPS could have same problem as the current one because nobody has made the determination of the ROOT CAUSE of failure for this SMPS. All they know is that they fail!! You will need to read all the posts here on fixya and elsewhere to maybe???? find out ROOT CAUSE and exactly what component(s) fail and more importantly WHY! It is now 2009 and these LVM-37W1 units have been failing by the hundreds because of SMPS failures since 2007 or 8 ! Yet nobody has investigated to COMPONENT LEVEL why the SMPS fails. Well, all I can say is good luck guy. If you do manage to get it up and running again I would certainly like to hear back from you. try me at
[email protected] or here on fixya. I'm 12fixlouie. Hope this was of some use! If yes please rate on fixya.
Westinghouse LVM 37w1 Screen goes
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
- No video, Power light is on or blinking.
- TV is making a clicking noise.
- TV takes a while to come on
- Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
My volume is working but no picture. what's up
please check wiring. might some interrupted wires or bad contacts cause no picture. check also brightnes and contrast settings. also problem could be inverter defect, or fault in power supply
Stays on 3 seconds then
Look on the power supply board for Bad Capacitors they will be Vented,swollen,or puffed up on TOP. 1000uf 16v 2200uf 10v 3300uf 10v.Shopjimmy has Power Supply board for 169.00
If no bad caps then replace the PSB.
Audio & visual come on, then video goes out.
The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these refurbishes 1 or 2 long LCD inverter boards for the replacement.Will fix this problems.
