20 Most Recent
Autotek Fx-3b Active Crossover Old School Questions & Answers
I got an autotek bts
for stereo
speaker #1 (white = pos ,green = neg.)
speaker #2 (yellow =pos. ,blue = neg.)
for mono
white = pos., blue = neg.
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Amp light is green getting a base like heart beat nothing else fuses are good
The only thing I'm wondering is if you shorted out the RCAs somehow. Try switching the RCA's to another output on the back of the deck, if you have more than one set.
If that's not it...you will have to add pieces of the system one by one, starting at the deck, to see if you can troubleshoot the problem. Very Odd.
Good Luck
Power turns on then 1 second after protection
MAKE SURE THAT THE POWER AND ESPECIALLY THE GROUND CONNECTIONS ARE 100%. REMOVE THE RCA INPUTS AND SPEAKERS. POWER THE AMPLIFIER UP AGAIN UNDER THIS NO INPUT, NO SPEAKER LOAD CONDITION AND IF IT STILL GOES INTO PROTECTION, THEN IT WILL NEED TO BE SERVICED. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE.......V
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
