20 Most Recent RCA Universal Remote Control Questions & Answers
I cannot imagine the original person still has this issue but if you turn off the cable box, assuming it is an HD PVR, you then hit the menu key and you can go into a whole bunch of options including cc
RCA Universal... | Answered on Jan 25, 2019
Anbonn led tv code pls
RCA Universal... | Answered on Dec 17, 2018
Need code for lte dvd player
RCA Universal... | Answered on May 08, 2018
Roku is a streaming player; it streams many types of data like comedy, TV shows, horror, etc. Many users had admired to use the Roku because of its comfort and easy to use. The Roku Universal Remote code Comcast is used to control your entire device.
    ·Roku Universal Remote is programmed to access different devices like as TV, DVD, and VCR player. It is a more interesting that you can control your entire device in your single remote.
    ·This remote control is used to control the audio and video of any brand of your device.
    ·This code is identifiers for configuration of your device.
    ·There are two code lists they are CL3 and CL4. Check this code list to replace your batteries and cover.
    ·You can execute your device in 2 methods
    1.Auto programming
    ·Use the universal remote to turn on your device.
    ·Then press "Setup Release" till TV button flashes.
    ·Enter the digit and choose the code to setup your device.
    2.Manual Programming
    ·Use Comcast remote, if you want to program then you can use Aux KEY.
    ·Check the instruction for manual and start entering the code. First ensure that you have a Roku account or else get it from the Roku.com/link. For details contact@ +1-844-965-4357.
1-rokuactivationcode-com-roku-universal-remote-code-comcast-blog-433sdnpnckpfjmjifzsr4nnb-5-0.jpg
RCA Universal... | Answered on Nov 07, 2017
try these
Code For Model RCR412S
Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV
you can find codes at http://remotefinder.rca.com/default.aspx?site=rca if you ever need codes for other.
RCA Universal... | Answered on Sep 05, 2017
i have a sansui and the caodes are 0135 and0310
RCA Universal... | Answered on Aug 12, 2017
Two things. "No signal" on a modern TV usually means the device connected to the corresponding input is either not configured right, is not set up for the type of cable you're using to connect its output to the TV, or the TV input "source" hasn't been switched to the actual input you're using. You mentioned a VCR, but I would take that out of the picture to simplify your troubleshooting, and just work with the converter box and the TV. If it still doesn't work, at least that means the VCR has nothing to do with it.
Then, it would be nice to know for sure whether the converter is sending the TV the "no signal" message, or the TV was doing it on its own. If you get the message and then disconnect the interconnecting cable, and the message stops, then we know the message is coming from the converter. If it stops, the that means the TV isn't even seeing the converter. See, we are just cutting to problem in half bit by bit, to determine exactly where the problem is.
Second, I sympathize and have little patience for a customer service rep that would give up so quickly. If the converter needs an antenna, then the CS rep should have advised you what kind of antenna it needs,and how to make sure its connected right. If a CS rep gave me such poor assistance, I'd return it for my money back and buy another converter. Its hard to know enough details to prove out exactly what is likely wrong, but these steps should at least help isolate some problems. And if it is the converter, at least you know one brand never to buy again.
RCA Universal... | Answered on Jun 02, 2017
Maybe you are doing something wrong. Have a friend try to do it and see what happens.
Universals leave lots to be desired and you might just have to get an original OEM unit.
RCA Universal... | Answered on May 03, 2017
Trata con el c?digo del DVD marca 3M, ese es compatible con el DVD marca pronext, por lo menos para las funciones b?sicas.
Aqu? detallan como lo usaron desde una app de smartphone:
http://tv.yoreparo.com/dvd/codigo-de-dvd-pronext-t626432.html
Saludos
RCA Universal... | Answered on Apr 26, 2017
The remote model number is CRK93J1
you can download the manual at:
http://www.replacementremotes.com/store/downloadpdf.cfm?productid=55977
RCA Universal... | Answered on Oct 26, 2016
It is best to contact any service technician in this case, and make sure that the TV is perfect. Check only after that.
RCA Universal... | Answered on Oct 17, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
RCA Universal... | Answered on Sep 01, 2016
If you wish to get some details about netflix; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
RCA Universal... | Answered on Aug 26, 2016
U get those codes, if any, from the manufacturer of the universal remote.
RCA Universal... | Answered on Aug 24, 2016
Televison & Video Logo
2,071 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
panasonic omnivision tv vhs combo unit
  • Televison & Video
