Since I was asking myself if the iPhone works with Google's VR Daydream glasses, we at our company tried it for myself, see in this video.
And it actually works but you should start with the iPhone 6 because the iPhone 5 and 5s is just to small. I attached a video which shows how it works. But still, no iOS app supports the Google Daydream control. But if you cannot wait to enjoy VR content, it is possible. Let's see when Apple will release some kind of VR glasses as well.
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
Home - SONOFF OfficialSONOFF Official
https://sonoff.tech
Explore the innovative world of SONOFF, learn and chose about various smart home products, define your smart home,your smart choice!SONOFF Products · Basicr2 · ZigBee Bridge · Home AUTOMATIONA Thorough Pairing Guide To SONOFF Smart Devices And ...SONOFF Official
https://sonoff.tech > product-review > tutorial > how-to-p...
How to quickly pair sonoff smart devices with ewelink app? This guide covers a complete and instuitive pairing instruction for all sonoff devices.Contact maker support. It is likely an issue with the new broadband router. The will know if there are compatibility issues..
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
White wire is RX or receive control. Red wire is TX or transmit control. Green wire is audio lead. Bare wire is audio shield or common.If for some reason your M2 has a different color code see the mic cable to M2 board connection.From the tab side it is audio(green), TX (red), shield, RX ( white).
