20 Most Recent
Samsung DVD-VR325 DVD Recorder/VCR Questions & Answers
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
6/24/2014 6:01:16 PM •
Samsung...
Answered
on Jun 24, 2014
Vcr - dvd player problems
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
3/14/2013 1:47:51 AM •
Samsung...
Answered
on Mar 14, 2013
Black box on screen blocking view of movie
A medium sized black box in the middle of the screen indicates the text feature is engaged.
Explanation:
For several years in the settings on many sets with closed captioning there was a option for "TEXT" and the idea was books and other written things could be transmitted on certain channels.
This never really got off the ground but millions of sets have this feature.
The TEXT box can come from one of two places:
In the set's customer menu look for CC (closed caption) and make sure TEXT IS NOT HIGHLIGHTED.
If you are using a cable or satellite box etc it can also come from that.
If you find it selected for TEXT 1 (there are 1-4 in most sets) either turn it to off or select something other than TEXT 1 and the box should go away. It could also be coming from an external source of something else connected to the set but this is not likely.
Check first CC with the set's remote to see what is turned on or off and LET ME KNOW WHAT YOU FIND.
Regards, SD TECH
5/2/2010 7:09:40 AM •
Samsung...
Answered
on May 02, 2010
Lost remote, will a universal remote work?
Hello and Welcome to FixYa!
You can go for universal remote. If works with all most all the popular softwares available in the market! i have checked it for Samsung. all universal remotes works for the model described.
Best of Luck,
Please Do RATE my solution, If found HELPFUL,
Concerned,
Waqar.
4/30/2010 3:36:57 PM •
Samsung...
Answered
on Apr 30, 2010
Fault code
my friend it is best to record your movies or music with a computer.as these DVDS Recorders are not compatible with certain types of dvd disc brand probably try another brand of dvd disc.and see what it does, try the memorex or the TDK.also dont use dvd recorders to record your movies use them to play back.they are problem.good luck.
6/23/2007 6:59:10 PM •
Samsung...
Answered
on Jun 23, 2007
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
