20 Most Recent
V_Wellcome Russell Hobbs 19000 Desire 600W 1.5L Bowl 2 Speed Food Processor With Blender IGN Questions & Answers
Do you have replacement bowls for Russell hobbs food processor ?
Hi Josephine:
Fixya is not a retail store that actually sells stuff.
We mostly give free advice.
Soooooooo.....
I'd suggest that if you can't get the bowl you need through whomever sells the units, you could try checking with a thrift store (such as the Sally Ann or local hospital auxiliary) to see if you can find the appropriate sized bowl.
Cheers
How to Order Food on Train?
To order food on a train, you can use various online platforms like IRCTC e-catering, RailRestro, or local vendors available at specific stations. Simply provide your train details and select your preferred meal options through their websites or apps.
Masterchef 65 I can't get the liquidiser to lock into place
If you are having trouble getting the liquidiser to lock into place on your Masterchef 65, here are a few things you can try:
- Make sure the blender jar and the base are lined up correctly. The grooves on the base and jar should match up perfectly.
- Check to see if the locking mechanism is clean and free of debris. Use a soft cloth to clean the locking mechanism and the area around it.
- Try pressing down on the jar while turning it clockwise to see if it will lock into place.
- If none of the above works, it may be possible that the locking mechanism is damaged or worn. In this case, you may need to contact the manufacturer or a professional repair technician for further assistance.
I hope this helps
What is a primary consumer
In a food web, a primary consumer is an organism that feeds on producers (plants) to obtain energy and nutrients. Primary consumers are also known as herbivores or plant-eaters. They occupy the second trophic level in a food chain, with producers at the first trophic level. Examples of primary consumers include rabbits, deer, cows, and many insects that feed on plants.
Hi I need hep to install addons for kodi on my phone . When I enter url it says no network. Wifi and url is fine. HELP xx
If you are trying to install addons for Kodi on your phone and are receiving a "no network" error when entering the URL, there could be a few potential issues to check:
- Make sure your phone is connected to the internet. Check that your Wi-Fi or cellular data is turned on and you have a strong signal.
- Ensure that you have entered the correct URL for the addon you want to install. Double-check the spelling and formatting to make sure there are no errors.
- Verify that the website hosting the addon is working properly. Try accessing the website on a different device to see if it loads correctly.
- Check that your Kodi settings allow for third-party addon installations. To do this, go to Settings > System > Add-ons and toggle on the option for "Unknown sources."
If you have checked all of these potential issues and are still receiving the "no network" error, you may want to reach out to the support team for the addon or Kodi itself for further assistance.
I need a food bowl for a Welco food processor R-118 FP-1
You can find a food bowl for a Welco food processor R-118 FP-1 online. You can search for the specific model number to find the correct bowl for your food processor. You can also contact the manufacturer directly to inquire about purchasing a replacement bowl.
Food chopper bowl and blade are stuck
The blades lift off. As long as the lid is off the bowl should rotate unless the safety interlock pin hasn't retracted. Press it down, let go and jiggle the bowl.
Pulse button on my old 11 Cup Food Processor no longer works?
Question edited for clarity.
Guessing it is a Food Processor, so question moved from Coffee Makers.
All questions need 'make model (what it is)' please, first 3 words.
You can try getting to the back of the button and spray it with Electrical Switch Cleaner.
Of Google
make model replacement parts
I've put the feed tube into my kitchen aid food processor in the wrong way. It's gone straight through and won't come back out. Help please
It sounds like you may have accidentally inserted the feed tube into your kitchen aid food processor upside down. If the feed tube is stuck and won't come out, there are a few steps you can try to remove it:
First, try gently pulling on the feed tube to see if it comes out. Be careful not to apply too much force, as this could damage the food processor or the feed tube. If the feed tube is still stuck, try turning the food processor upside down and gently shaking it to see if the feed tube falls out. If the feed tube is still stuck, you may need to use a tool to help remove it. A pair of pliers or a pair of needle-nose pliers can be helpful in this situation. Carefully grip the feed tube with the pliers and gently pull it out. If none of these methods work, it may be necessary to disassemble the food processor to remove the feed tube. This should only be done as a last resort, as it can be challenging to reassemble the food processor correctly. If you are not comfortable with this, it may be best to seek the assistance of a professional.
