20 Most Recent Amazon Fire TV Stick Questions & Answers
2answers
Amazon Firestick. How to change postal code on my Firestick please?
Question edited for clarity. Question moved from Computers. How to change location on Firestick
  1. From the Home screen, go to Settings.
  2. Go to Preferences.
  3. Select Location.
  4. Input a postal code for your desired location.
Jan 19, 2023
How to Change Location on Firestick: Country settings hack
2/29/2024 8:36:38 AM • Amazon Fire TV... • Answered on Feb 29, 2024
2answers
Why can't I register it?
Fire tv stick can't register - Amazon.com
https://www.amazon.com/gp/.../ref=cs_hc_g_tv?...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to get past the wifi connection screen. But registering it with my Amazon account is I'm possible. Tried over 50 times ...
Amazon.com Help: Basic Troubleshooting for Amazon Fire TV
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.Make sure your Amazon Fire TV device is registered to your preferred Amazonaccount. To verify your registration ... Can't Access External Storage. Note: External storage options are not available for Fire TV Stick. First, make sure you're using ...
Amazon.com Help: Can't Connect to Wi-Fi
7/27/2022 7:46:52 PM • Amazon Fire TV... • Answered on Jul 27, 2022
2answers
Wont accept registration details
Amazon.com, Inc.... five seconds. Or, open Settings > System > Restart from the main menu. ... Note: External storage options are not available for Fire TV Stick. First, make sure ...
Amazon.com: Customer Discussions: Connecting Fire Stick to Wifi
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Dec 21, 2014 - No questions asked. .... I have the same problem because my network is considered open ... I'm trying to connect to a friends Xfinity wifi with fire tv stick, I have my laptop, Ipad & phone all working thru it but TV Stick won't. ... Mine wouldn'taccept password until I connect the HDMI extender - works fine now. Fire TV Stick keeps asking for ... Jan 3, 2015 KIndle Fire HD won't accept ... Nov 2, 2014 How do I re-register my new ... Mar 11, 2014 kindle won't connect with wi-fi May 7, 2012 More results from www.amazon.com
7/27/2022 7:46:47 PM • Amazon Fire TV... • Answered on Jul 27, 2022
2answers
Jailbreak fire TV stick
Here's an article that gives a couple of options for jailbreaking your Amazon Fire TV Stick. Jail Break Amazon Fire TV Stick
7/27/2022 7:46:44 PM • Amazon Fire TV... • Answered on Jul 27, 2022
2answers
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
7/27/2022 7:46:41 PM • Amazon Fire TV... • Answered on Jul 27, 2022
Received new first stick with Alexa voice remote. Followed set up nothing happens..what am I missing?
Have u got an Amazon account as u need one to set it up
7/26/2022 9:37:57 PM • Amazon Fire TV... • Answered on Jul 26, 2022
2answers
Fire tv stick missing Kodi app, How do I get it installed?
Here's an excellent tutorial on how to do it ( and where to get it). How To Install Kodi on Fire TV Stick Computer Not Needed
7/26/2022 2:36:46 PM • Amazon Fire TV... • Answered on Jul 26, 2022
5answers
My firestick remote wont work
1.Replace batteries.(in remote) 2.Get within 12 inches from firestick. 3.Press and hold home button for 10 seconds. This should now pair with firestick, and should work.
1/24/2022 10:42:22 AM • Amazon Fire TV... • Answered on Jan 24, 2022
Having trouble signing in on tv doesn't respond to my password
let's start with the basics first in order to solve your Amazon firestick issue. Once we go that, we can move forward as necessary. The default tv password is 0000 (4 zeros). In ordet to set it back to this state, you can press the following keys in the given order: mute 8 2 4 [power-button] . Please double check that the tv is turned off before pressing those buttons from your remote control . Please let me know if this helped you or not.
10/17/2021 6:09:38 PM • Amazon Fire TV... • Answered on Oct 17, 2021
When changing programs it continues to move and does not stop until the end. Does not change one at a time.
let's start with the basics first in order to solve your Amazon firestick issue. Once we go that, we can move forward as necessary. It sounds like one of your channel-changing buttons is stuck in the "down" position. I would suggest removing the batteries from your firestick remote and then pressing the channel up/down buttons (used to change the channel) to "unstick" the button. Please let me know if this helped you or not.
10/17/2021 6:05:08 PM • Amazon Fire TV... • Answered on Oct 17, 2021
Network connection lost and can't navigate around screen
let's start with the basics first in order to solve your Amazon firestick issue. Once we go that, we can move forward as necessary.Amazon recommends that you restart your fire device by unplugging it's power for 1 minute and then powering the firestick device again. If this doesn't work, then you'll need to choose settings > network > then find your network name > then you can press play/pause to to check your network status.If you need any more help you can find the video in this link and/or start from step #5 as well: amazon.com/gp/help/customer/display.html?nodeId=GYMDPRQTTLXQD7PL&IWcIBc-1b4a9e Please let me know if this helped you or not.
10/17/2021 5:33:55 PM • Amazon Fire TV... • Answered on Oct 17, 2021
2answers
How do I Jailbreak a Firestick? Is Jailbreaking a Firestick Legal?
Hi John! To answer your question off the bat, jailbreaking a firestick is completely legal. You are actually not jailbreaking anything, but instead just loading third-party apps onto your firestick. Loading third-party apps onto your device is legal and is allowed by Amazon. However, you could potentially get into trouble depending on what you are streaming with the third-party apps. If you are streaming something on the public domain then you are fine, however you may get into hot water with your ISP or government if you stream some things for free that are not on the public domain. It is important if you decide to jailbreak a firestick to always use a vpn so that your personal data on what you are streaming is protected and anonymous. For a full tutorial on how to jailbreak a Firestick, I would check out Cord Cutters Anonymous. The website is great and will explain everything you need to know about jailbreaking a firestick and will show you the best apps available out there currently. Here is the full blog for how to jailbreak a firestick -> http://cordcuttersanonymous.com/how-to-jailbreak-firestick/ And here is the Cord Cutters Anonymous home page where you can sign up for a newsletter to always be updated with the best firestick apps to load onto your device. -> http://cordcuttersanonymous.com/ Hope this helps! -mark
10/13/2021 10:25:41 AM • Amazon Fire TV... • Answered on Oct 13, 2021
Setup fire stick getting unable to update fire stick
Is it a second hand 1 if so the previous owner might have left there amazon on account so it's no use if it's pre owned
10/9/2021 9:29:43 PM • Amazon Fire TV... • Answered on Oct 09, 2021
2answers
How do i register my amazon firestick
Plug Firestick into TV. Select Firestick port as input source on TV Follow instructions on TV.
10/7/2021 9:49:58 AM • Amazon Fire TV... • Answered on Oct 07, 2021
2answers
How do I register?
Register or Deregister Your Amazon Fire TV - Amazon.com
Amazon.com, Inc.In order to use your Amazon Fire TV device, register it to your Amazon account. ...Differences between Amazon Fire TV and Fire TV Stick ยท Amazon Fire TV ...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to ... But registering it with my Amazonaccount is I'm possible. Tried over 50 ..... How do I contact Customer Service?
Amazon.com Help: Fire TV Stick Help
7/14/2021 7:41:30 PM • Amazon Fire TV... • Answered on Jul 14, 2021
How can I get the KODI app for my fire stick
Here's an article that explains the process. It also provides two videos for adding Kodi to the Amazon Fire Stick Jail Break Amazon Fire TV Stick
7/12/2021 12:06:51 AM • Amazon Fire TV... • Answered on Jul 12, 2021
2answers
How do I enter the credit card expiration date "as they are given in the challenge"?
you have to enter it exactly as is on the card
9/4/2020 11:33:23 PM • Amazon Fire TV... • Answered on Sep 04, 2020
6answers
Fire tv stick missing kodi app, how do i get it installed?
Here's how you can (re)install Kodi on Fire TV Stick: Kodi 17 Firestick How to Install FAST EASY TV Addons KFireTV
8/12/2020 2:56:08 AM • Amazon Fire TV... • Answered on Aug 12, 2020
4answers
I have accidently wiped KODI off my fire stick how do I get it back?
You can reinstall kodi on firestick with a lot of methods but one of them is given as follow Similar to other methods, this method too requires you to enable installation from "Unknown sources." Once you do it, follow these steps. Before these steps STEP 1: Search FireDL on your Fire Stick. STEP 2: Install FireDL and Open it. STEP 3: Type 600003 at the top blank space. STEP 4: The above code will automatically convert to the Kodi APK URL and download will start without any further actions from your side. You can then install some great addons and builds to further enhance your experience. 19 Best Kodi Builds To Experience The Colors Of Kodi
6/8/2020 11:36:57 AM • Amazon Fire TV... • Answered on Jun 08, 2020
Amazon Fire TV Stick Logo
594 questions posted
Top Amazon Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Amazon Televison & Video
Most Popular Question
free up space fire stick tv without
  • Televison & Video
