20 Most Recent Samsung HLN467W 46" Rear Projection HDTV Questions & Answers
I have a Samsung HLN467W TV and a Toshiba
Use Google or Bing and search for an HDMI to VGA with audio adapter. Be careful not to mistake the VGA with audio to HDMI adapter. They are not the same device and some internet locations have very limited descriptions and can be confusing.
1/4/2018 11:33:10 PM • Samsung HLN467W... • Answered on Jan 04, 2018
I have a samsung HLN467W DLP and when I turn it on
if all three lights on the front blink when it stops then yes. you can removed the colorwheel and inspect it most of the time if the sound is loud the colorwheel is shattered
4/3/2016 5:32:47 PM • Samsung HLN467W... • Answered on Apr 03, 2016
Is there a reset button after I replace my lamp on my samsung dlp hln467wx?
the following website will guide you thru resetting lamp timer. while in this menu DO NOT MAKE ANY OTHER ADJUSTS AS YOU CAN GET THE TV IN A POSITION THAT IT WILL NOT OPERATE.
1/31/2015 9:27:26 PM • Samsung HLN467W... • Answered on Jan 31, 2015
0answers
Relay switch keeps shutting off
Hello Jamie, Do you mean the house power relay? or is there a relay on the TV? if its the TV, and it is hooked up to a multi power outlet, try connecting it directly to the wall and see if this happens.. hope i can be of help!
1/16/2014 8:57:54 PM • Samsung HLN467W... • Answered on Jan 16, 2014
Samsung dlp tv wont turn on, blinks lamp light green and temp light red
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
2/6/2013 1:49:06 PM • Samsung HLN467W... • Answered on Feb 06, 2013
Hln467w picture flickers
lower the brightness (to 7 from 9) and watch it in the Movie mode
8/4/2012 5:43:21 PM • Samsung HLN467W... • Answered on Aug 04, 2012
No sound on HLN467W
look to see if somehow speakers in the set got switched off.
6/14/2012 3:26:54 AM • Samsung HLN467W... • Answered on Jun 14, 2012
4answers
Samsung DLP Check Fan #3
where is fan #3 in samsung dlp
4/25/2012 10:58:05 PM • Samsung HLN467W... • Answered on Apr 25, 2012
Hi I have a Samsung
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
3/19/2012 5:46:40 PM • Samsung HLN467W... • Answered on Mar 19, 2012
White Flashing
DMD Control Module is flaking.
Could be getting hot if the fan has been compromised by dust. Take the back off. Clean everything with a brushy on the vac hose. Tape the cover switch shut and power up. Check for proper fan operation. Both should spin equal and quiet. May be too late for DMD Control board, though.
3/19/2012 5:43:43 PM • Samsung HLN467W... • Answered on Mar 19, 2012
3answers
Check fan 3 comes on samsung DLP tv
Its a tiny fan inside the silver cabinet where all the plug in jacks are. It keeps the pc boards in the cabinet cool. Most of the time you can blow out the dust in the fan with canned air. If this doesnt work, you will need to replace it. Partsstore.com carries them. You have to get the exact match since the TV reads the amperage so computer cooling fans wont work.
8/14/2011 4:17:54 AM • Samsung HLN467W... • Answered on Aug 14, 2011
My HLN467W/HLN567W TV won't turn
This is an older model projection tv that uses a bulb to generate the light for the screen. It's normal that the bulb wears out after all these years - it should have been replaced before complete failure. If the inverter/ballast board (the one that powers the bulb) has been fried when it failed it's normal that the tv refuses to turn on - if it would do that the damage would become a lot greater.
Now the damage is done. To fix it the tv must be opened and the boards, starting with the power source and the inverter ones, tested. This is something only an experienced repairman can do, you will have to find and call one . It will be expensive, around $750 , or even more if you were unlucky and some other board was fried when the bulb failed. You now have to decide it the tv is worth all this money or you just cut your loses and buy a new one.
7/28/2011 5:47:46 PM • Samsung HLN467W... • Answered on Jul 28, 2011
Samsung HLN467W 46" Rear Projection HDTV Logo
103 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
samsung dlp check fan 3
  • Televison & Video
