20 Most Recent
Cavs Premier-99 Plus Questions & Answers
SPINS CDS BUT WON'T READ THEM.
Do you have the right CD's? if yes, first use a cleaner to clean the laser. if still it does not read, open player and see if theres a ribon connection that came loose. If there is none, then have somebody troubleshoot the read circuitry.
My hyundai premier 99 karaoke player have audit but no video display.
First make sure your video cable is ok. If it is, there is a chip inside that switches video sources which can burn. Use the s-video output to get the video. Use an s-video to composite video adapter cable to match your tv if you prefer. The s-video output bypasses this chip.
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
I need a replacement remote control for JVC NX-BD3 network media system
If you wish to get setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search easy.
