20 Most Recent Sceptre NagaIII X30SV 30 in. HD-Ready LCD Television Questions & Answers
12answers
Sceptre X30SV LCD display goes black with sound... Inverter? and other parts...
I too have the same problem...Searched and waited long time for parts. I have replaced everything and the thing still flashes and goes blank but has sound. Not worth anymore stress. My neighbor is an electrical engineer who I used to think can fix anything. He too is baffled. My fix suggestion... Getting a new LCD (not a Sceptre) tonight...with an extended warranty...Sceptre (and their tech's) no help if you don't have a warranty. I learned my lesson!
2/17/2017 11:54:33 PM • Sceptre NagaIII... • Answered on Feb 17, 2017
3answers
TV will not power up
My Sceptre X30SV had no power. I unscrewed the panel where the power supply is (in the back of the tv) and unplugged the power brick. Shortly after I plugged it back in and it has worked for the past 24 hours. I'm thinking my power supply is on its way out. I have purchased a voltage meter, how do I go about testing the power brick?
Thanks for your help in advance!
12/2/2014 11:10:15 PM • Sceptre NagaIII... • Answered on Dec 02, 2014
MY LCD HDTV HAS LOSS POWER IT JUST SHUT COMPLETELY
Check and replace its main power regulator circuit board.
8/11/2013 1:25:57 PM • Sceptre NagaIII... • Answered on Aug 11, 2013
2answers
Screen goes blank after a second
This is an easy fix! You have a bad "power inverter chipset" To fix this issue you will have to search google for a power inverter for this particular model of lcd. It's basically just the chip that the power cable plugs into on the lcd. More than likely it's going to be cheaper for you just to buy another t.v... Sorry. I know these T.Vs like the back of my hand. I've seen this issue with hundreds of LCDs because I work for a company that fixes them. FYI - It is not your backlight because if that is broken the monitor would not even flash. It is not your VGA because if that was busted you would not see any video.
9/22/2011 5:47:52 AM • Sceptre NagaIII... • Answered on Sep 22, 2011
2answers
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
9/22/2011 5:46:20 AM • Sceptre NagaIII... • Answered on Sep 22, 2011
We do not know how
check the back side of the monitor, or on the side of the monitor you will find the RCA connection through this side. the input of the video player comes in three colors, yellow for video output, red and white for audio output. just put the connector on its color allocation properly
7/22/2011 4:55:50 AM • Sceptre NagaIII... • Answered on Jul 22, 2011
It turns on but dosent stay on it turns its self
it ie a ground proglem. confirm all connections to be true, ie/ kinda tightenthem. Then unplug the thing and plug it back in and presto!
8/29/2010 1:59:34 AM • Sceptre NagaIII... • Answered on Aug 29, 2010
I WOULD like to change the cabinent to black
hi, ive found sticky back plastic works great,you can get this cheap on ebay,OR ,try aerosol,simply mask of the holes ,lighly sand ,and give it a go.if you make a mistake just let it dry ,sand it ,and try again.GOOD LUCK
2/12/2010 5:04:25 PM • Sceptre NagaIII... • Answered on Feb 12, 2010
Replaced all the capacitors in the power supply is the best bet to solved the power shut down.Becauce capacitors is unprodictable very small amount virable dip in Micro farets the whole power board will shutdown.Capacitors testing with the voltage meter is very hard to determine the micro farets in and out went power in use or power it off.
2/10/2010 6:42:20 AM • Sceptre NagaIII... • Answered on Feb 10, 2010
My sceptre won't show my pc screen, it keeps going
I believe you are trying to display too high of resolution to this screen.
Try using a lower resolution. If you had 1024x768 then try 800 x 600.
11/19/2009 9:47:01 PM • Sceptre NagaIII... • Answered on Nov 19, 2009
Hi, my tv turns itself
The sensor is detecting some voltage anomaly on the board and is invoking safety shutdown. This may begin to happen more and more frequently until eventually it wont turn on again and by then the task of fixing will be greater than now. It would be better to have it looked at and the solenoid checked to see if IT is the problem or that there is a failing IC chip on the power board that causes the spike that is activating this behaviour.
Please remember to rate the help++++Thanks for using FIXYA
10/11/2009 5:48:40 AM • Sceptre NagaIII... • Answered on Oct 11, 2009
Screen goes black after powering up sound is just fine.
The backlight video board inverter it dead,need a new one.
10/3/2009 10:30:53 PM • Sceptre NagaIII... • Answered on Oct 03, 2009
Sceptre NagaIII X30SV 30 in. HDTV-Ready LCD Television powers off
Look at the top right venting louvers above the power cord receptacle. A green LED glows when the power supply is providing voltage to the TV. If the LED is off, you'll have to check the wall receptacle for 110 Volts, check the power cord and check to see if the power supply is getting 110 Volts. If you have voltage in and nothing out of the power supply then buy a new one off E-Bay. Quite often electronic devices will "turn off" when warmed up because of expansion of a faulty connection and "turn back on" after it has cooled. Also, their could be a safty thermo switch within the power supply that is sutting things down because of over heating. So, it's a **** shoot. I fixed mine with an E-bay AC adapter.
3/1/2009 5:50:13 PM • Sceptre NagaIII... • Answered on Mar 01, 2009
2answers
Hello...
Unfortunately, this is still a project.
Let me get back to you about this.
Back to you soon. I will get back on this tonight.
Basil
12/7/2008 11:51:31 PM • Sceptre NagaIII... • Answered on Dec 07, 2008
Where can I get inverter for X30SV-Naga III
when you turn it on there is a saying in the right hand corner saying tv off
11/30/2008 11:21:21 PM • Sceptre NagaIII... • Answered on Nov 30, 2008
Sceptre NagaIII X30SV 30 in. HD-Ready LCD Television Logo
40 questions posted
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Televison & Video
Most Popular Question
lcd hdtv loss power just shut completely
  • Televison & Video
