20 Most Recent
Samsung Galaxy Tab S 10.5" Tablet - 16GB, WiFi, Titanium Bronze Questions & Answers
Why does my new Samsung 10.5 tablet take so long to charge.If you
My first question would be, do you have the factory charger? If not is your ac adapter the right volts and mah? If not you may be experiencing a " trickle charge. " This is where the device is charging but only at a trickle like speed. This happens often with Apple products, when they update all your previous charging cords are useless. Try using a new updated usb charging cord too.
How do i upgrade the android on my galaxy tab s 10.5
You should receive updates automatically If you go into settings on the top click on General then scroll down to the bottom of the left hand column then click about device then on the right at the top is software update click that it will show when it was last updated under that is Auto update make sure you have that checked then you will always have the latest updates.
if you go back to about device you can then see model number, android version and other details. I have android version 4.4.2 at the moment everyone gets the latest updates at different times you just need some patience.
Hope this helps
Tablet problems with touch of the screen
let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary.
I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started.
If that doesn't work, then you can perform a factory reset as described by Samsung here:
https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset.
Please let me know if this helped you or not.
