20 Most Recent
TDK 8mm MP 120 Minute Premium Camcorder Tape P6-120 8mm Tape Questions & Answers
Always look for Video Splicing tape on google
<span><b>Never!!!</b> Never use Scotch tape on your audio or videotape, eventually a chemical reaction will cause the glue to melt down and leak to adjacent parts of the tape and damage it beyond repair. Splicing tape is specially formulated for magnetic Mylar tape, Guaranteed not to melt or bleed.Splicing Blocka device used for positioning and holding down a section of magnetic tape while splicing and joining splices with splicing tape</span>
The tape film has been
use scotch tape to reattach tape
trim carefully so no extra tape hangs over sides
the "magic" tape works well - it is one that dissapears more when you rub it hard
I would like to tranfer
It requires a specific software program to be able to do it.I found that out when researching about my VCR tapes to computer to DVD.Although I do not know how successful you will be with 8mm.Just search for it at various stores.Or better yet,begin by checking with your camcorder manufacturer to se if they know anything.Good luck,Greg
I have video cassett size 8...I dont have the
look online or in some electronic stores for an adapter--the tape fits into a vhs format case and the vhs adapter is inserted into player theirs a vhs play adapter made for just about all compact tape units
Sonilex mp3 player
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjb3NfpyqODAxV8pIkEHdrGARoQFnoECCIQAQ&url=https%3A%2F%2Fwww.flipkart.com%2Fsonilex-sl-mp16-8-gb-mp3-player%2Fp%2Fitmeamgzmehkuxfy&usg=AOvVaw1cDMtU5SJ-HeoZJow0fXKZ&opi=89978449
Tdk data recovery
You can try 4Card Recovery. It is freeware and very helpful. Detailed steps are here. And it's quite easy.
Step1. Download 4Card Recovery on your computer and launch it.
Step2. Select the files that you want to recover, or you can choose to recover all.
Step3. Choose the 'next' button to scan it and just wait for about ten minutes.
Step4. Keep your recovered data or files on other part, this is very important.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Can not format
at command prompt type chkdsk x: /f /r where x is the flashdrive /memory card
Online ups
Hi amin_amin
Check to make sure the switch on the side of the card is not locked
Can't remove write protect from my tdk flashdrive
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open Right click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply Hope this helps.
