20 Most Recent
Samsung Galaxy S5 Questions & Answers
I want to revive my Galaxy S5
Suggest you move on. If you really want another S5 buy used off of ebay, but for same $100 get a used S7 (better CDMA/GSM).
How to sync all photo content to Samsung tablet at once
You can download dropbox from the Playstore. Setup an account, and you will get 50 gb extra because of the deal they have with Samsung. You will be able to sync your photos and videos from each of your Android devices, plus your computer.
I want to unlock my galaxy s5
If the phone has had service for 12 months the carrier will unlock it for free. You do not need to unlock most phones if you are taking them to most prepaid carriers. Calm the carrier you plan on using before doing anything else.
SM-G900W8 reset password
Here is another way to unlock screen lock for Samsung Galaxy phones, works with pattern, password, fingerprint and Pin. no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Disassembling Samsung Galaxy S5
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera. Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward. Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot. Remove the microSD card from the phone.
To know more about disassembling procedure follow the link
http://electro-medical.blogspot.com/
I want to forward a voicemail to another phone
call settings in settings
write down the current call diversions to voicemail settings in case you want to change it back !
Put in phone number put area codes in to the phone number.
But also be aware there may be call diversion charges each time call is diverted ! you may need to check with provider
Also be careful if your phone is in another country roaming could become very costly, you may need to check with provider
