20 Most Recent
Indesit BIAA134F White 9.5 Cu Ft Fridge Freezer Bottom Freezer, A Rating Questions & Answers
Ondesit fridge fridge freezer biaa134fh fridge not cold
It seems lots of people have the same problem with this appliance....including myself......I took the drawers out of the freezer.....removed the iced up plastic cover which houses the fan assembly.....some water had settled in the bottom and froze, therefore stopping it from turning.....just spin it and it with start up again.....hope it helps ;)
My Indesit fridge does not get cold, both the Refrigerator and Freezer.
ok.. none of what you have done involved taking the back off.. if you can get to the compressor itself, you will find it has a dinky 'computer' style fan.. but invariably, some fool of a designer, runs wires very close, and uses low quality cable ties.. which break, causing the wires to spring up and jam the fan.. (especially if it has been moved recently) significantly reducing your compressors ability to chill your appliance.
get some decent cable ties, check and secure rogue wires, and things should sort themselves back to the right temperatures within a few hours.
4/24/2017 12:38:12 PM •
Indesit...
Answered
on Apr 24, 2017
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
6/9/2015 3:57:17 PM •
Indesit...
Answered
on Jun 09, 2015
Freezer is working ok but the fridge is not cooling down
8/12/2014 1:52:30 PM •
Indesit...
Answered
on Aug 12, 2014
