20 Most Recent
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Questions & Answers
How to plug a blu-ray dvd in my theaterwide tv...i have a hdmi converter to componant but no images.....thanks
Your TV cannot reproduce 1080p resolution so go into the menu setup of bluray player and make sure resolution is on 1080i and not 1080p. I understand you will have to do this on another TV capable of 1080p or if your bluray player has a composite output (yellow single rca) then hook that up as it may be active at the same time into your AV in on the TV. Once you have picture, then you can enter the setup menu as I have indicated above. I hope this solves your problem.
7/9/2016 3:44:28 AM •
Toshiba...
Answered
on Jul 09, 2016
52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
2/4/2016 11:35:44 PM •
Toshiba...
Answered
on Feb 04, 2016
How do I get samsung sp67l6hx2x/xsa into service mode
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
5/19/2014 11:00:43 AM •
Toshiba...
Answered
on May 19, 2014
What is the meaning of each blink code ?
On Mitsubishi RPTVs there can be 3 dots on the front and how/when the blink can be interpreted as codes. Do you have a POWER, a LAMP and a TEMP light on your TV?
4/28/2014 4:13:51 PM •
Toshiba...
Answered
on Apr 28, 2014
Tv reset menu
On the front there should be a panel you can open if you dont have a remote. On that panel there should be a reset button.Just press it while the tv is on.
11/7/2013 8:25:06 PM •
Toshiba...
Answered
on Nov 07, 2013
I have a 65hm117 tv. It has white spots and every
I have the same problem with my 65HM117. Funny, but it started just when I was getting a FREE repair for a Samsung LCD tv with bad caps on the power supply about the same age as the 117. The problem according to Samsung tech (who was kind enough to look at it while he was here) is the DMD (digital mirror device) chip, the "processing" part of the DLP (Digital light processing). Suggested I call Toshiba. Toshiba rep, obviously not in the USA, told me Toshiba doesn't make DLP's anymore "because of all the problems." They apologized repeatedly, repeatedly pointed out the unit is "out of warranty," but NO help or recal even though they know they built a product with defective, unreliable technologyl. Bottom line, Toshiba lost a customer but SAMSUNG has one for life! I'd repair it, but can't find the part number for the board with the DMD...
8/12/2013 9:09:44 PM •
Toshiba...
Answered
on Aug 12, 2013
