20 Most Recent
Tamron 18-200mm f/3.5-6.3 for Nikon Questions & Answers
I took it apart some time ago and i need a service
Hi,Welcome to FixYa.Unfortunately, the service manual is currently unavailable for download as the manufacturer provides the copy of the service manual only for the use of authorized service centers.Thanks for using FixYa.
This Tamron used with my Canon 1000D gives since 3
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
The glass on my 18-200 lens was cracked on the
hi there...
so sorry to hear that your lens was cracked...
the reparation will costs you expensive enough, and i suggest you buy a new one
if the lens still working, you still can use it taking pictures, but the picture will need some correction using photoshop or any other graphic software
thanks
My lens will not zoom when the zoom ring is
I'd contact
Tamron Tech Support. These are not cheap optics and they are assembled with precision. Opening the lens could cause contamination or further damage resulting in an even costlier repair, if out of warranty. Most Tamron lenses are covered by up to 5 years of warranty - provided you haven't opened it up - or abused it.
I hope this helped - good luck!
The camera tech says one of the elements is smoky
The only way you could get a replacement element is from the manufacturer, and they probably won't supply one. Your only realistic option is to send it to Tamron for repair, but if it is not in warranty, this may be too expensive to be practical. I also doubt that you will find a genuine service manual for this online, though some sites may seem to offer one.
The Tamron 18-200mm lens extends and changes
not a lot the lens is a big heavy lump to hang on the camera mine do the same thing,,,best bet is use shorter lenses not just one big cannon hanging off the frount that can zoom in on a fly at 1000 yds
My tamron lense is locked, I don't remember doing
If it's only two months old then it's still under the manufacturer's warranty so send it back to Tamron. I can't tell you where to send it as you haven't said which country you're in. Tamron value their reputation and usually provide excellent after-sales care.
If you're in the UK you additionally have Sale of Goods Act protection for up to six years in England and Wales and five years in Scotland. Either way, the Act allows you to demand a full refund or replacement from the retailer; I'd suggest a refund as bad lenses often come in batches and a different supplier is less likely to have one from the same production batch.
Note that any attempt to fix the lens other than by normal use of the lens and camera controls may completely remove your warranty benefits or consumer protection.
"Taken from another answer from a guru on this site"
Aperture not going below 6
There is no problem. The lens is f/3.5-6.3. That means that at 200mm the maximum aperture is f/6.3. At long focal lengths you will not be able to open up beyond f/6 or so. At the short end, at 18mm the maximum aperture is f/3.5.
ERROR 99
try cleaning the lens contacts of your lens and camera.
Tamron18-200 f/3.5-6.3
Tamron has identified this problem with the Canon. See link: http://www.tamron.com/about/updates_canon.asp, but I am not sure about your Nikon.
