20 Most Recent
Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Questions & Answers
Caller ID problem with KX-FHD332
Your fax machine does not actually have CALLER ID, it reads what the sending fax machine has programmed into it. If it was never entered in, you won't see it.
1/14/2010 4:36:49 PM •
Panasonic...
Answered
on Jan 14, 2010
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
9/19/2009 11:37:27 AM •
Panasonic...
Answered
on Sep 19, 2009
Panasonic fax kx-fp153
Please try this
- Turn off the printer.
- Remove any paper trays. Inspect them for wrinkled or damaged paper.
- Also open the back cover of the printer if this model has one.
- Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
- If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
- If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
- If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
- Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
- If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
- see alternative if the problem is still not solved.
alternative :Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
6/11/2009 3:33:54 PM •
Panasonic...
Answered
on Jun 11, 2009
Phone line reversed
The tip and ring (red and green) wires in the phone line are the ones that are used in this instance and there is technically no polarity (+ or -) because the current on this line is AC. Much like household current most device will work no matter which way the plug is inserted. There are polarized plugs which only work one way just to keep everything standard. Long story short: this should not be a problem under normal conditions.
1/22/2009 3:45:02 AM •
Panasonic...
Answered
on Jan 22, 2009
Memory full
This machine should actually print the stored jobs when you have paper in it. It may have a job in memory that is to large for the memory, if that is the case it would need to be cleared by turning the machine off and on.
You may also want to go to Panasonics website and look at the user manual for this machine as well.
1/17/2008 9:41:59 PM •
Panasonic...
Answered
on Jan 17, 2008
