20 Most Recent Toshiba MW27FP1 27 in. TV/VCR/DVD Combo Questions & Answers
0answers
My Toshiba model# MW27FP1 worked
The fail safe circuit has been engaged to prevent fire and further damage to some of the components inside the set. There is possibly an open circuit or short on the power board or even on the sustain boards of the display and colkor engine. NOT a DIY operation, without ability to read a cicuit diagrams have the right tools and be able to assess voltage outputs.
Thanks for using FIXYA
6/11/2010 3:08:50 AM • Toshiba MW27FP1... • Answered on Jun 11, 2010
My DVD player keeps freezing and skipping scenes.
Try cleaning the optical pickups you can either take covers off and use isopropyl solution with a clean cloth to clean mirror or you can try a cd/dvd cleaning disc from most electronic retailers.
5/23/2010 7:20:39 AM • Toshiba MW27FP1... • Answered on May 23, 2010
Only has a line through center of screen
Problem started as a simple cold solder joint. Now the connection has either burnt to the point of not making any connection at all, or the vertical output has gone out due to the stress. As far as the dvd player goes. Sounds like the microprocessor is heating up and going bad. Nothing can be done other than replacing the whole unit.Should be able to order it from Toshiba.
2/11/2010 5:36:51 AM • Toshiba MW27FP1... • Answered on Feb 11, 2010
Where are the vertical deflection caps located
Check C421, C427 and C429. These capacitors are located nearby IC401. IC401 is mounted on a heatsink and has the following markings on the body LA78041
2/11/2010 4:17:53 AM • Toshiba MW27FP1... • Answered on Feb 11, 2010
TV has line through center of screen
thats the VERTICAL OUTPUT IC or TRANSITOR that went bad , need to take unit to a TV repair shop , hope it helps AJ
11/19/2009 12:11:30 AM • Toshiba MW27FP1... • Answered on Nov 19, 2009
TV will not power on
Hi
Thanks for using FixYa. If your TV is not powering on then it is due to faulty powerboard. The capacitors on the power board maybe swollen or bulged.
You'll need to replace these capacitors and/or the wholeboard. You can buy the parts from these links--
ToshibaMW27FP1 parts
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
11/1/2009 6:41:30 PM • Toshiba MW27FP1... • Answered on Nov 01, 2009
My Toshiba MW27FP1 will not turn on but is making
Ur high voltage is dead,FBT,the flyback transformer is dead,the block of plastic with a red wire with a cap hook to a CRT(tv tube).
10/3/2009 10:53:26 PM • Toshiba MW27FP1... • Answered on Oct 03, 2009
Switching on problem Goodmans tvc201t
The TV is on protection.
Protection is a special diagnostic mode that will keep the TV in standby as an internal fault had been detected.
The clicking noise is the protection switch that keeps turning the TV off to prevent further damage.
The fact that TV restarts after unplugging lets think to a fault on power supply board inside TV.
When you unplug TV you discharge PSU capacitors, and that is the reason why the TV restarts afterward
First test the unit on a different socket. If you are using a surge protector, remove it.
Try also leaving the TV unplugged for a longer time, let say several hours.
Also unplug all connected device, and leave only the aerial cable, a defective receiver box or DVD can cause the same problem.
If that does not solve the problem, then the TV is faulty, probably a defective PSU (power supply) board. The part must be tested before replacement.
In this case, locate any good qualified repairer.
or
If you want to DIY you find parts here. You will find schematics and diagram to test the TV on the service and repair manual that can also be purchased from the seller below.
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
5/16/2009 3:32:20 PM • Toshiba MW27FP1... • Answered on May 16, 2009
3answers
Why is it i only get line 1, line 2 and channel 3?
Sounds like your not seeing the full menu;
Can i suggest buying "All 4 one" remote from ebay? I have included a link below - they are very cheap and will work with you TV/DVD/Sat all at once.
http://cgi.ebay.co.uk/New-Universal-Remote-Control-GREAT-PRICE-3-98_W0QQitemZ140302539872QQcmdZViewItemQQptZUK_AudioTVElectronics_Video_RemoteControls?hash=item140302539872&_trksid=p3286.c0.m14&_trkparms=72%3A1690%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
I hope this helps,
Thanks.
3/15/2009 3:46:52 AM • Toshiba MW27FP1... • Answered on Mar 15, 2009
2answers
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
11/29/2008 9:03:59 PM • Toshiba MW27FP1... • Answered on Nov 29, 2008
6answers
Lines across the top
Possibly interference?
9/12/2008 11:45:26 AM • Toshiba MW27FP1... • Answered on Sep 12, 2008
DVD player keeps skipping
It sounds like the problem is with the DVD's you've been playing. I've gotten those problems before, but not on every DVD. How many different ones did you try playing?
8/22/2008 12:37:15 AM • Toshiba MW27FP1... • Answered on Aug 22, 2008
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it: Check Mute and Volume: Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume. Inspect External Speakers: If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues. Test Different Inputs: Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box. HDMI Troubleshooting: If the issue persists with the DVD player over HDMI, consider the following: HDMI Cable: Check the HDMI cable for damage or loose connections. Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary. Mainboard Replacement (if needed): If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard. TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM • Toshiba... • Answered on Apr 07, 2024
Toshiba 72HM195 has started getting red streaks
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
3/25/2024 5:27:53 AM • Toshiba... • Answered on Mar 25, 2024
Change batteries on my toshiba se-r0001 remote
  1. Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
  2. Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
  3. Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
  4. Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
  5. Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
  6. Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
  7. Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
  8. Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM • Toshiba... • Answered on Mar 09, 2024
Toshiba MW27FP1 27 in. TV/VCR/DVD Combo Logo
20 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
dvd player keeps freezing skipping
  • Televison & Video
