20 Most Recent
Aiwa F2000 20" TV Questions & Answers
How to restore facory settings for aiwa tv-a2119ke
To do a factory settings, you have to enter its service mode using its remote control. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Need a servive code for ic tda11105
It sounds that the kit fitted with the TV is of Philips. If you wish to get
more details, check the site linked here. It has service mode entry procedure to many brand TVs. Search the site by type in the IC number. Hopes it will help you.
Dead set no sound picture tube totally blackout. unit goes while watching tv program
If the unit has shut down during watching a program, there are mainly to reasons. The first one is its EHT section, and the second one is its main power regulator section circuits. Contact any service technician. Troubleshooting to this kind of fault is somewhat skilled one. If you wish to
get some details, check the site linked here. Pull up older posts. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service center.
TV is making loud whistling noise
If you have a spare cable set, try using this in place of the existing one. Is it only one of your inputs that is doing this? If you have 2 inputs that are connected, first try switching the cables. If this doesn't fix it then it is either a problem with the tv or the input device. If the problem moves to the other input then you need to replace the cable. If switching cables doesn't work, switch to a different input. If this fixes the problem then there is an issue with the input on your tv. If neither of these fixes the problem then it is most likely a problem with your device.
Most likely there will be a problem with your cable connecting the device to the tv or with the connection between the cable and the input. If you think that it is a problem with the tv (ie. the female input socket) then I suggest getting it repaired (expensive I know) or you might be able to get a friend who is good with electronics to take a look at the connection.
Aiwa service mode
Press and hold Vol+ & Prog (-) key at the front panel of the TV, and plug on the Power. If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Service mode entry, adjust and exit procedure to many brand TVs are given in detsil.
Sir i have a problem w/ my tv. w/ i turn it on it
You probably used the wrong capacitor or it requires to change more than one. Check and make sure that there are no more burned capacitor or transistors that may cause such as failure. Good Luck!
AIWA TV-A2119 PROBLEM: SOUND MENU NOT COMING
THE PROBLEM IS YOUR TV MODE HAS BEEN RECONFIGURED TO KE1 MODEL. SO YOU WILL NOT GET THE AUDIO MENU. THE SOLUTION IS, JUST BUY AN ANOTHER REMOTE RC-ZVT03 MODEL AND USE IT AS A TEST JIG REMOTE. OPEN THE COVER, YOU WILL SEE THE CONTROLLER IC BW7461-3T ( 16 PIN). ACTUALLY TO ENTER IN TO THE SERVICE MODE, WE HAVE TO PRESS THE "TEST" KEY. BUT THAT KEY IS NOT AVAILABLE IN THE REMOTE. SO SIMULATE THE 'TEST' KEY, JUST SHORT THE PIN NO 4 AND PIN NO 12 THROUGH A WIRE TO ENTER IN TO THE "SERVICE MODE". ONCE YOU PRESSED THE PIN 4&12, THE TV WILL ENTER IN TO THE "AGEING MODE". THEN PRESS "AV MODE" SWITCH IN THE ANOTHER REMOTE ( YOUR CASE ZVT13). A MENU WILL APPEAR TO SELECT THE MODE. PRESS NUMERIC KEY "3" (INDA-1) TO SELECT THE "AIWA TV-A2119KE" MODEL AND AGAIN PRESS "AV MODE" TO EXIT. AGAIN PRESS THE TEST KEY TO EXIT. RESTART YOUR TV. NOW YOUR PROBLEM SOVED. SINCE I ALSO FACED THE SAME PROBLEM, I GOT THIS SOLUTION (jp_ati).
Enjoy.
Dr. M. Jayaprakasan, Chennai
Aiwa A2119 Tv setting codes
I have Aiwa A2119 model and I am facing sound problem, as all other things are working perfect but sound is automatically gone I don’t know why. Can you help to solve it?
your help will be greatly appreciated.
With regards,
Ash
I have AIWA A219 TV.
Hello
Its front panel microswitches are struk. These can be replaced. They are microswitches, which can be resoldered out from the front panel board. For this, you have to open your TV, take out the front panel after unscrewing it from the cabin, desolder one out of it and go with that microswitch as sample. You can bought it from electronic spare part shops at your town. Buy all of them and replace all at same time. This will solve your TVs problem. OK.
