20 Most Recent
Vtech InnoTab 3S The Wi-Fi Learning App Tablet, Pink Questions & Answers
How can I gt my vetch innotab screen to work
is there any sound at all coming from the toy? if there"s no sound try pressing the power button down for 30 secs without any powersource...after that place batts back in and try turning it on. if it doesnt work you may want to call their hotline
My sons innotab 3s won't charge
try usiing just the charger without the rechargeable batts...if toy turns on with just that then prob maybe eiither the toy itself or you need new rechargeable batts
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
No Sound
The volume control does not work? I think this one is already defective and needs to be replaced.
Troubleshooting innotab screen
have you tried calibrating the screen? You can do this by pressing the Home Button, question mark, and volume up button all at the same time. Turn the toy on without letting go of the other three buttons until you see the Touch Calibration Screen. If this does not help, then I suggest you call Vtech. Contach info is available at
www.vtechkids.com if you no longer have the manual.
