20 Most Recent LG WT1201CV 4.5 cu. ft. Ultra Large Capacity Top Load Washer with Fron Questions & Answers
I have LG washer wm2016cw got OE code. I am attempting to remove the drain pump filter. I removed the drain filter cap, but the filter is did not come out. Is their a trick to get the filter out.
To remove the drain pump filter on your LG washer model WM2016CW, try gently wiggling and pulling it after removing the cap. If it's stuck, apply lubricant sparingly and tap around the edges. Comparing with your mother-in-law's similar model might offer insights. If all else fails, refer to the manual or contact LG support for assistance.
4/11/2024 4:51:23 PM • LG Washing... • Answered on Apr 11, 2024
LG Fuzzy Logic 8.2kg WF-8071TTP washing machine doesn't dissolve the soap and leaves marks on the clothes.
You are using the wrong type of detergent. Use liquid instead of granulated powders. They don't dissolve in low temperatures. https://www.manua.ls/lg/wf-8071ttp/manual?p=8 ..
4/7/2024 7:25:34 PM • LG Washing... • Answered on Apr 07, 2024
A new LG dryerDLE7150W. It will run for 10 minutes then shut off and have a nP code. checked everything from the panel to the cord connections and it is good.. I have 221c at the outlet. any clue?
An nP display code indicates that there is a problem with the electrical wiring in the home and that no current is being detected at the heater.
2/8/2024 3:03:16 PM • LG Washing... • Answered on Feb 08, 2024
I have a LG WM2688HWM washing machine with a spin problem.
This has a new fangled direct drive motor. Normally the fix would be to replace the motor controller or one of the capacitors on the board, but this has none of those, and appears to be run by one control board and that is no longer available. Try cleaning the connectors to the control board with electrical switch cleaner spray. Your best bet is to call for service and hope they can replace the part that is preventing the spin cycle. https://www.searspartsdirect.com/model/1nx1gwawbm-003204/lg-wm2688hwm-washer-parts Some videos on that issue ..
2/1/2024 4:26:00 PM • LG Washing... • Answered on Feb 01, 2024
LG WM2010CW won't spin: Error code In:81, IU:00
check belt if ok check under agitator possible bad cogs
12/8/2023 9:15:32 PM • LG Washing... • Answered on Dec 08, 2023
I have a problem with my dishwasher LG 425. It shows an error at the end of the washing process. The error is BE. What is it related to?
Wrong washing deterjant being used and machine not leval . Google your machine with the error code and you find a u tube link on this that will help you
12/7/2023 11:19:05 PM • LG Washing... • Answered on Dec 07, 2023
LG LMN187HVT Mini Split Heat Pump. Error codes for it please?
Question edited for clarity and toss in some CAPS.
DEFINING COMMON ERROR CODES
LG HVAC https://lghvac.com > resource-service > filenam... LED2. (Cooling LED). 1. Indoor unit return air thermistor has disconnected or has shorted out. 1X. -. 2. Indoor unit inlet pipe thermistor has disconnected ... 2 pages https://www.google.com/search?q=lg+lmn187hvt+error+codes ..
12/1/2023 11:54:25 PM • LG Washing... • Answered on Dec 01, 2023
My LG front end loader has the drying light flashing in the cooling light to stainless
This is a 'front end loader'. https://www.google.com/search?q=front+end+loader Google LG (model number) light flashing No idea what you mean by drying light flashing in the cooling light to stainless and I have been reading the question since yesterday! ..
11/29/2023 8:32:22 PM • LG Washing... • Answered on Nov 29, 2023
3answers
What causes a washing machine main PCB board to die?
110 volt home mains supply? 17.9 volts over is pushing it a bit if you get any voltage surges on top of that. Integrated Circuits have a relatively low tolerance. I would change machine brands.
11/11/2023 7:44:00 PM • LG Washing... • Answered on Nov 11, 2023
LG washing machine fix unplug plug in works
Question makes no sense as written. Is this what you mean?
We have to unplug the washer and plug in everytime ...
JustAnswer https://www.justanswer.com > Appliance Repair Dec 12, 2020 - Unplugging the washer will reset the issue one cycle at a time, but to fix the issue completely the main board will need to be replaced. This is ... 1 answer ยท Top answer: This is a very common way for front load LG washers to fail. The problem is that the main ...
WM3470HVA LG Washer won't turn on until I unplug for 10 ...
Appliance Blog https://www.applianceblog.com > ... > Washers > LG Jan 8, 2017 - My LG Washer just started an issue where it won't turn on when pressing the power button. But if i unplug it for 10 seconds, then plug it ... FIXED - WM3360HVCA LG Washer Won't Power On Sep 30, 2019 WM3470HWA LG Front Load Steam Washer Won't Turn On Aug 17, 2016 More results from www.applianceblog.com It appears to be a VERY well known issue! https://www.google.com/search?q=LG+washing+machine+fix+unplug+plug+in+works ..
11/10/2023 9:37:38 PM • LG Washing... • Answered on Nov 10, 2023
IU-00 code LG washing machine not doing the spin circle
Did you ever get help with this? No one answered about the IU:00 error code, and it doesn't show in the LG manual.
11/5/2023 4:11:20 PM • LG Washing... • Answered on Nov 05, 2023
I have an LG washing machine. It has a PF code. Simple things don't fix it
As LG states in troubleshooting section, If your unit is displaying a "PF" error code, it means you've experienced a power failure. This may occur if the power supply to the washing machine is interrupted during a cycle from a power outage. To fix this, simply restart the washing cycle LG Washer - Error Code List ' LG USA Support
11/3/2023 12:16:33 PM • LG Washing... • Answered on Nov 03, 2023
Can I replace bearings on my LG washer myself
Yes, but it is complex. And all I can offer are two general guides you will have to surf through. If you save them as PDF, they may be searchable by one of the PDF readers. Search for bearings. I can't find a service manual for the particular machine but can provide a link to the user manual. Maybe the YouTube I list will help. You can also call LG Customer support for assistance. If they can't directly help, and they might, they could refer you to a technician who could. Go to the LG page and find customer service. 6 Most Common LG Washing Machine Problems and Solutions (kcscfm.com) 5 Common LG Washing Machine Problems and Troubleshooting - DIY Appliance Repairs, Home Repair Tips and Tricks (howtofixit.net) Here is the link to the user manual:www.croma.com/lg-10-kg-5-star-fully-automatic-front-load-washing-machine-fhp1410z7p-apsqeil-smart-diagnosis-platinum-silver-/p/260607. https://www.youtube.com/watch?v=j5FjmK0yYFk
10/27/2023 10:23:46 PM • LG Washing... • Answered on Oct 27, 2023
3answers
I have got a front
Is the washing machine giving off a hot machine oil smell or making a grinding noise when the tub is turning? I've had to replace the drum bearings several times on LG front load washers. The first sign that the bearings are going are loud noises when the drum is spinning and eventually the hot machine oil smell. The bearings can be replaced but they usually last only 6 months to a year. The bearings are put on with a press at the factory and unless you are very accurate, you won't be able to get them on exactly straight and they will wear out quick.
10/27/2023 10:07:56 PM • LG Washing... • Answered on Oct 27, 2023
How to enter LG WM6700HBA Test Mode?
https://www.youtube.com/watch?v=l3AdJIXjOaI https://www.manualslib.com/manual/3039218/Lg-Wm6700hba.html If you don't have the manual, download it from that site and search the manual for "test mode". S number of applications can search a pdf.
10/15/2023 4:00:06 AM • LG Washing... • Answered on Oct 15, 2023
2answers
My LG 7.2kg model WF-T7016PP automatic washing machine turns on but doesn't wash, what may be the problem
Check that the magnet that is fitted to the lid of the washer is present or whether it has moved.
10/10/2023 9:08:05 PM • LG Washing... • Answered on Oct 10, 2023
LG washer OE drain error inconsistent
User manual https://gscs-b2c.lge.com/downloadFile?fileId=KROWM000189904.pdf says on page 28 and 30 for 0E error. It says Drain hose is kinked or clogged, drain filter is clogged. Clean and straighten the drain hose and Clean the drain filter.
9/25/2023 1:06:26 PM • LG Washing... • Answered on Sep 25, 2023
LG WT1201CV 4.5 cu. ft. Ultra Large Capacity Top Load Washer with Fron Logo
2 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
lg wm2016cw front load washing machine
  • Washing Machines
