20 Most Recent ESCHMANN Little Sister Autoclave Tabletop Questions & Answers
Check the drain pipe that vents steam through resevoir at end of cycle , could be simple debris blockage, or vent valve not opening,play safe autoclaves are like accidents waiting for a place to happen -steam under pressure..
ESCHMANN Little... | Answered on Feb 21, 2019
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
ESCHMANN Little... | Answered on Aug 09, 2018
Might be several things. First though, verify that your power outlet can provide enough power that is specified to operate.
ESCHMANN Little... | Answered on Feb 23, 2015
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
ESCHMANN Little... | Answered on Jan 02, 2015
That is an autoclave and peoples life and health depend on it. Please contact the manufacturer at +39 0445 329811
Science &... | Answered on Sep 27, 2019
1. Always clean the slide. 2.Make sure that the fine and the coarse adjustment knobs do not scratch the slide by handling them gently.
Science &... | Answered on Sep 05, 2019
Turn it on and bring up the temperature. The pressure inside will increase as the temperature increases.
Science &... | Answered on Aug 19, 2019
The fault table is on page 15 of the following document.
http://frankshospitalworkshop.com/equipment/documents/autoclaves/service_manuals/Eschmann_SES2000_-_Service_Manual.pdf
Further support may be channeled through the distributor. As with many devices, it is suggested to have mainteance and repair done by personnel trained specifically in such for the devices. There is quite a bit of information in this manual one might wade through Page 28 lists error codes and error 2 listed refers to door open during cycle.
UK Customers Eschmann Equipment, Peter Road, Lancing, West Sussex BN15 8TJ, England. Tel: +44 (0) 1903 765040. Fax: +44 (0) 1903 875711. Overseas Customers Contact your local distributor. In case of doubt contact Eschmann Equipment.
Science &... | Answered on Jun 19, 2019
A User Manual for the Variscope Binocular 40x to 1000x microscopes is available from Amazon online:
http://www.manuallibrary.net/1475-40x-1000x-biological-binocular-user-manual.html
Science &... | Answered on May 19, 2019
Each letter refers to a cardinal direction North West East South, so press n e w n e w s.
Science &... | Answered on May 18, 2019
Manuals are available from PHC. Email service@us.phchd.com or call Technical Support at 800-858-8442 ext. 48299.
Try here:
https://www.optiboard.com/forums/showthread.php/8260-Lensometer
Science &... | Answered on Apr 26, 2019
You have a microscope with a camera in or on it? And the cord goes to a tablet computer? And "pulled up codes to download" means whet? "Pulled up"? "codes"? Did you "download"?
Most operating systems will use a graphics program to accept an image from a TWAIN device like a camera or a scanner. Perhaps you could use something like that.
I have used some different programs with cameras and scanners under Windows long ago (XP and Vista).
Science &... | Answered on Apr 18, 2019
Without a brand name and model number or any pictures, it is not possible to guess what you have, where the light is, what wires or switches might be on it.
Sometimes it is just a simple tightening of the bulb or cleaning of battery contacts to get it fixed.
GIVE YOU 1 GUESS IF YOU HAVE TO ASK HERE IT IS NOT YOU
Science &... | Answered on Mar 02, 2019
Saturn.. The first five are Mercury, Venus, Earth, Mars, Jupiter.
Science &... | Answered on Feb 27, 2019
Fun fact. Uranus could have been called Georgium Sidus in honor of King George III. Or Herschel in honor of planet's discoverer. But finally was chosen Uranus because since Saturn was Jupiter's father, the new planet should be named after Saturn's father. More useful information about this planet you can find here https://solarstory.net/planets/uranus
Science &... | Answered on Feb 01, 2019
ESCHMANN Little Sister Autoclave Tabletop Logo
5 questions posted
Top ESCHMANN Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you an ESCHMANN Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • ESCHMANN Science & Laboratory
Most Popular Question
eschmann ses 2000 autoclave steriliser
  • Science & Laboratory
