20 Most Recent Apex Digital PF2020 20" TV Questions & Answers
4answers
How to unlock telefunken TV set
I would reccomend the following: Press and hold in the "display" button on the remote for about 5 seconds.
This worked for me
Thank you, Regards
6/28/2018 11:13:14 AM • Apex Digital... • Answered on Jun 28, 2018
Bought a used Apex t.v.
Take it back!!
1/20/2018 7:48:29 PM • Apex Digital... • Answered on Jan 20, 2018
2answers
Telefunken tv
To turn off the child lock,press and hold the F key and press MUTE.
11/3/2015 4:37:04 PM • Apex Digital... • Answered on Nov 03, 2015
How to unlock my apex tv without a remote
You can't do it without its remote control. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
12/23/2013 6:15:09 AM • Apex Digital... • Answered on Dec 23, 2013
manual
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
11/1/2012 8:08:18 AM • Apex Digital... • Answered on Nov 01, 2012
CHILD LOCK RESET
Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes. • Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button. Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688." Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
11/1/2012 8:02:29 AM • Apex Digital... • Answered on Nov 01, 2012
How do i watch movies on my tv.
Click here to download the user manual to this TV. It has all details you want to know.
9/11/2012 8:58:38 AM • Apex Digital... • Answered on Sep 11, 2012
2answers
22 inch G Tech tv stuck on child lock PLZ HELP!!!!!
Dot listens to that idiot
And try in any way can find to get the remote (original or copy) from your surrounding people and deactivate the child lock or take the TV set to repair shop to solve it from inside.
11/4/2011 9:25:27 AM • Apex Digital... • Answered on Nov 04, 2011
3answers
Permant child lock
Sorry man The only way I know to unlock it is with the original remote. They are available at http://www.remotes.com You have to press the M or Mute button and the F or the Function button at the same time. If the remote you have has these buttons try them. Like I said if it doesnt work, you will need an original remote. See if anyone you know has one you can borrow or the store where you bought the TV, maybe they will let you borrow one. Good Luck
11/4/2011 9:15:52 AM • Apex Digital... • Answered on Nov 04, 2011
Can I play in Hd
Hello
You can give any video input to your Apex TV. Component input must be connected ot its DVD in sockets at its rear panel according to the markings[Cr, Cb, Y] from the source device. Audio must be connected to appropriate audio in sockets, and select the input to TV respectively. OK.
8/31/2011 9:55:49 AM • Apex Digital... • Answered on Aug 31, 2011
0answers
I cant turn off tthe child lock
Push f then mute this will fix the problem.
7/23/2011 3:18:19 AM • Apex Digital... • Answered on Jul 23, 2011
Need to replace the fuse
Your local Home Depot will likely have fuses, I suggest googling and information about the specific type of fuse you may need and checking the store site to find if they have the item in stock.
7/17/2011 10:03:25 AM • Apex Digital... • Answered on Jul 17, 2011
Lock the channel.than how to
Hello
T unlock your Apex TV do the following. Apex TVs use a four digit code to control the V-Vhip. For most models it is 6688. Other sets may not have one, or may have a default lock code 1225 instead of an override code.
To use the override code:-
Press menu key to get into Menu.
Go down to the 'System' menu, and hit the right arrow on the remote control.
Once in the system menu go for "parential Guide" It will ask you the code.
Enter the override code listed above. From here you can turn ON and OFF different rating settings and to set a new code.
No matter what the V-Chip code is set to; the override code will work. If you have a blank screen, showing a red Key on the bottom left side of the screen, simply press the [Function or F] button togetherwith mute button at the same time. This will unlock the screen and allow you to view the channel as you desire. OK.
4/8/2011 4:19:14 PM • Apex Digital... • Answered on Apr 08, 2011
Apex tv code
try that code# for apex tv #236, #023 #032. good luck!
5/17/2010 5:52:16 PM • Apex Digital... • Answered on May 17, 2010
Apex Digital PF2020 20" TV Logo
39 questions posted
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
unlock apex tv without remote
  • Televison & Video
