20 Most Recent Apple 21.5" iMac Desktop Questions & Answers
Have an Imac and I lost password and no disk
2/16/2016 10:57:27 PM • Apple 21.5" iMac... • Answered on Feb 16, 2016
BOOTING
2/16/2016 11:32:15 AM • Apple 21.5" iMac... • Answered on Feb 16, 2016
Re set apple id password
There are only two ways to change your apple id: 1: Use your password and reset it. 2: Use the link below. There is no way to fake it, steal it, or otherwise use amy but the 2 methods above. https://iforgot.apple.com/password/verify/appleid
11/13/2015 4:53:52 PM • Apple 21.5" iMac... • Answered on Nov 13, 2015
2answers
Cant send nor receive emails on my imac
Is it connected to router and showing connected
10/6/2015 9:33:24 AM • Apple 21.5" iMac... • Answered on Oct 06, 2015
2answers
Why can't I use the back button?
Maybe your button was broke. Try to use another keyboard to check whether is your keyboard's problem or your iMac system wrong.
7/21/2015 4:47:10 AM • Apple 21.5" iMac... • Answered on Jul 21, 2015
What does this error code mean...4SNS/1/C0000008 TL0P==124
It's a temperature sensor error, usually the fans run at maximum rpm when this happens. The error indicates the LCD temp sensor is either reporting out of range data, is disconnected, or has failed. It is probably a damaged or disconnected sensor cable. A disconnected or missing sensor would simply force the fan(s) to run fast to protect the system.
3/31/2015 8:22:29 PM • Apple 21.5" iMac... • Answered on Mar 31, 2015
My imac 5.1 is half black screen
This is a service / back light repair issue.
8/20/2014 6:28:34 PM • Apple 21.5" iMac... • Answered on Aug 20, 2014
I bought a new imac. OS X version: 10.9.1. I'm having trouble printing to my HP Office Jet 5610. Not all the words or images are being printed. Sometimes its an entire area of a page. Sometimes it
Before printing, you can choose the page setup option (either above or below the 'print' & 'preview' selection) to make sure paper size & type of paper(usually legal is default setting) selected. Also make sure the drivers for that printer is up to date. What kinds of images are you wishing to print out? Most pages have html which prevents certain images or words from being captured/printed
2/8/2014 6:03:36 PM • Apple 21.5" iMac... • Answered on Feb 08, 2014
Powered off during reboot after being unplugged.now stuck in restart mode
Hi Tricia, under normal circumstances, when doing an installation on a hard-drive already containing a previous windows installed partition, all files and folders will be placed in a *windows.old* folder on your (C:) drive. in your dilemma i see one of 2 options, option 1) get a copy of *HIRENS BOOT CD* and boot from this, copying all your data to an external source, this can be done via USB or CD which ever you prefer, Option 2) although the easiest way to get out of this problem is to do a completely new installation on your system, however this way you might lose data if it is not from a windows 7 OS to another. if you need more advise, please do ask :-)
1/30/2014 9:29:42 AM • Apple 21.5" iMac... • Answered on Jan 30, 2014
How do I delete this item, it's the wrong one.
If its the wrong one, then don't delete it. If its the right one, then delete it.. Who knows, since you clearly have not provided enough information to make any sense whatsoever.
12/10/2013 5:03:46 PM • Apple 21.5" iMac... • Answered on Dec 10, 2013
Region unlock code for imac drive
Apple will not reset your drive (unlike every other hardware manufacturer on the planet), so once you have changed your region code 5 times, that's it... sorry.
12/7/2013 5:59:24 PM • Apple 21.5" iMac... • Answered on Dec 07, 2013
Imac bluetooth and usb not working
Simply you can't alone, probably you have problems with your southbridge on motherboard. Usualy this can be solved with rebaling. Is a common problem because - probably - you not clean your mac regulary.
11/30/2013 4:18:08 PM • Apple 21.5" iMac... • Answered on Nov 30, 2013
Disassembled imac 21.5 late 2009 cleaned fans put back together powers up fans go everything sounds normal but it dosent come on my external monitor I can't use imac screen as it is broken
Assuming you had a working machine prior to cleaning it, I would suggest you visit this site to follow instructions for the 27". The procedures are very similar (and nothing currently available specific to 21.5 yet) Understand that the process requires very tedious gentle handling of several cable connections that CAN EASILY BE DAMAGED if you are not extremely careful. I have performed several disassembly procedures on these models and they MUST be done with the proper tools and precise attention to detail. If not you can easily damage the delicate connections. Every screw, fastener, piece of tape, has a specific purpose and any item left out will likely result in a failure. Retrace your steps using the instructional guide (linked to above) and you may yet save the day. good luck and take a deep breath before starting!
4/29/2013 8:00:50 AM • Apple 21.5" iMac... • Answered on Apr 29, 2013
Need help with imac im locked out
Problem: Your Mac got locked via iCloud and on boot displays "Enter your system lock PIN code to unlock this Mac." It also sets an unknown password on the firmware so you can't boot from a disc. And you don't know the PIN code for a variety of reasons (not my business). lockscreen.jpg Solution: Mount the locked drive on another machine, find the PIN, re-install the locked drive into the original Mac, enter the PIN, resume your business. Tutorial: *I'm going to post the steps I did in my case and suggest steps you might take if your case varies. Things Needed: 1. Alternate machine with space to mount an additional drive. (works on Mac or PC*) *If you're using a PC, you'll need to download and install Mac Drive to be able to read the contents from a Windows environment. 2. You might need a SATA to USB adapter if you have a laptop without room for an additional drive. 3. Screw driver to disassemble the Mac. Step 1: Remove the locked hard drive from your Mac. You can find detailed guides for your specific machine at http://www.ifixit.com/Device/Mac Step 2: Install the drive into your alternate machine. But make sure you do *not* boot from it. Boot from your regular drive. If you do not have an alternate machine, feel free to ask a tech buddy of yours to lend you their machine. Step 3: Once booted into the alternate system, locate your locked drive. In my case it was drive D: on Windows. Now browse to \Users\username\Library\Application Support\iCloud pindirectory.jpg Step 4: In the folder "iCloud" find a file named with a bunch of numbers: ##########.lock In my case it was: 1138515150.lock pincode.jpg Step 5: I'd suggest that you take a picture of this file name for accurate reference. But you can also just write it down. Step 6: Once you got the number, power down the machine and remove the locked drive. Step 7: Install the locked drive back into the original locked Mac. Follow your iFixit guide from Step 1 in reverse to put the drive back. *It is important that you put it back in the machine where it was originally locked* so that the motherboard firmware will be unlocked in the next step. Step 8: Boot up the locked Mac and referencing the number you recorded, you can start trying 4 numbers at a time for the PIN. Try the first 4, then the second 4, and so on.. For example: 1138, 1385, 3851, 8515, 5151, 1515, 5150. In my case the PIN was the second to last 4 digits: 1515 If you typed in more than 10 combinations, then it says that you are locked out for a minute. Just restart the machine and continue entering the combinations from where you left off. Once you enter the right PIN, the Mac will instantly reboot proceeding to where you were at when the lockout occurred. It will also remove the firmware password.
3/15/2013 7:01:41 AM • Apple 21.5" iMac... • Answered on Mar 15, 2013
Print from iPhoto
Select your photos and select print. You can also order prints online through iphoto, selecting your photos first and then going through the menu bar to order prints.
11/13/2012 2:43:04 PM • Apple 21.5" iMac... • Answered on Nov 13, 2012
My firewire port is not working
Driver issue. Verify sound card is showing up by connecting while viewing system profiler.Verify support and download drivers from sound card manufacturer website.
10/21/2012 5:31:36 AM • Apple 21.5" iMac... • Answered on Oct 21, 2012
My imac firewire port in not detecting my firewire sound card
Verify support and download drivers from your sound card manufacturer's website.Open up Mac System Profiler by clicking the Apple in the top left, then about this mac, then go in to more information. Connect the firewire sound card and see if it becomes detected but is simply unknown. This will be a sure fire way of determining problem is with lack of drivers.
10/21/2012 5:30:50 AM • Apple 21.5" iMac... • Answered on Oct 21, 2012
How do you print a 4x6 on a
Make sure you use the full driver set from HP instead of any inbox drivers that come with OSX. Option for 4x6 will be available in print setup preferences.
10/21/2012 5:19:16 AM • Apple 21.5" iMac... • Answered on Oct 21, 2012
How can fix Erro 1009
Actually you can't, it means that the content you requested is not available for you country.
10/20/2012 9:21:41 AM • Apple 21.5" iMac... • Answered on Oct 20, 2012
Apple 21.5" iMac Desktop Logo
40 questions posted
Popular Products
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iMac Apple
  • iMac Apple
Most Popular Question
39 t enter voice chat rooms in yahoo
  • Computers & Internet
