20 Most Recent
94 95 96 97 Chevy S-10 S10 Pickup Billet Grille Grill Questions & Answers
96 s-10 starts but wont stay running , gauges die
you need to start with electrical first check electric wires and plugs,pay special attention to distributer.then I would check ignition moduals and fuses too. if this proves not to be problem then check fuel,for a faulty pump or clogged fuel filter,also a bad fuel pump. you can also check your ignition key and column,,if it is worn it could be disconnecting after you let go of the key. if you can not find anything hook it up to a code reader and see if it tells you a possible problem. then if this does not cure problem take it to a qualified mechanic in your rea.hope this helps.
Gas in the oil
Do you have the 4.3 vortec engine? If you do the pressure regulator under the plenum leaks fuel into the engine or they had problems with the injectors sticking open and bleeding down when the engine is shut off
Tail and brake lights
You will have to splice the wires back together and it should work. If it doesn't, post back with a little better description of the probem, Thanks:)
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
- Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
- Manually open the power sliding door completely.
- Manually close and latch the power sliding door.
- Turn the power sliding door ON/OFF switch to the ON position.
- Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
- Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM •
Chevrolet...
Answered
on Sep 09, 2022
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM •
Chevrolet...
Answered
on Oct 30, 2015
