20 Most Recent
Russell Hobbs 10617 Glass 2-Slice Toaster Questions & Answers
Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
I have a problem with
I would advice you check the user manual manual for this, because i cannot tell specifically the IC that is worn out, all you need to do is remove the IC, look at the top of the IC, you will see the number written on the IC, besides, you can take the IC to any electronic workshop to get the exact IC of your device.
Take care.
I have a 10617 2-slice
Hello, jonI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
I need a user instruction
You can download the instruction manual by clicking on the following link.(http://www.russellhobbs.co.uk/pdf/product_236_14356.pdf ).Please don't forget to rate me if satisfied.Good Luck.
Heats on one side only
Friend,
Obviously only one side is getting current or only one element is functional. Eitherway, please open the sides of the toaster on the nonfunctional side and check if the wiring to the element is ok. If connections are OK then the element may have got burnt. Please replace it and reconnect the wires and close the sides.
I have just bought 10617
It sounds like the unit has failed, I don't know what you could possibly do at your current location. You are going to at least need a new heating element and replace it, and if you are going to do that you may as well get a new one. You can contact the manufacturer and claim a warranty on it and they will ship you a new one, that is your best bet if there is no possible way to return it.
Thanks
Tim
Lever does not stay down
Buy a new toaster.
After a week or two return the broken toaster to the shop saying it won't work and ask for a refund.
My toster does not ssstay in ON position. The IC
An integrated circuit constructed to provide control functions to a toaster oven cooking appliance. The control functions including compensation for input voltage fluctuations, compensation for residual heat due to recycling, audible signal generation, multiple mode selection, safety shut off and others. The integrated circuit also provides flexibility to accommodate multiple models of an appliance in a product line. If you have the tools and the part, you can fix it yourself otherwise to the repair shop
