20 Most Recent
Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E Questions & Answers
Valve settings.
you will need the model and type numbers from your engine to find the correct clearance numbers
Battery isn't charging.
check to see if the machine has a regulator in the charge circuit as that will be where a problem will be
How do you stop gas leak around the bowl
The reason for gas at that point is the needle valve is not seating. The problem will be either bad float or bad needle valve. Most likely will be the needle valve is bad. Replace needle valve and carburetor gasket. If it has been doing this for more than a few hours you will need to double check your oil as it may have gas mixed in the crank case. If there is gas in the oil you would need to repair the carb and change the oil before starting the engine. Make sure not to over fill the oil. Hope this will help ya
How do I adjust the brakes on my bolens lawn tractor
depends on what gear box you have but usualy the brake is on the left side of the gearbox,there will be a rod or spring attatched to an arm, in the centre of the arm at the bottom will be a nut,either a nyloc nut or a castleated nut which will have a split pin running through it. all you have to do to adjust the brake is turn the centre nut clockwise. i have attached a pic of a gearbox and the arm i mentioned is number 41 in the diagram
Blade will not engage
There must be:
- Someone in the seat
- Not in park/idle.
- A working blade start switch
- A non defective PTO clutch.
- Undamaged blade and greased blade bearings.
Lawn tractor wont start
How do you know the battery is fully charged? Simply hooking a battery up to a charger does not ensure that the battery is being charged. The symptoms you mention are indicative of a dead battery.
Free belt diagrams
There is no way to get the diagram without knowing the model number. The model number will be under the seat most likely.
