20 Most Recent
Daewoo DSL-17DW3 17.1 in. HD-Ready LCD Television Questions & Answers
Left side of the screen goes in vertical lines
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me. Have your display system set back to factory defaults to see if this will do the trick as well.
Need install insructions
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
I have a daewoo pdh42L40 monitor and it does not
1. the infrared receiver may be defective and may need replacement.
This will require service from a qualified tech to replace.
2. or you may have a dead remote. check the batteries also in the remote.
No picture at all on daewoo lcd tv
I have a problem that looks similar. After some research and troubleshooting, I believe that the problem with my TV is the A/D decoding chip that takes care of the component video inputs. These chips are not simple analog to digital converters. They understand the component video (YPbPr) signals and need to sync to them at the various transmission frequencies and convert them to 3 digital YUV data streams with the correct number of pixels and dimension. I am only a computer engineer, but I guess these chips probably aren't very reliable or last very long...
Try to use your TV with different input connectors and resolutions. If some of them work correctly, it is likely the A/D thing.
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
Necesito el codigo de un control universal
English: the universal remote codes for Daewoo TV are: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Try those - I hope they help a bit.
Spanish: los c?digos alejados universales para Daewoo TV son: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Intente ?sos - esperanza de I que ayudan a un pedacito.
I had to translate (roughly) from the asker's question. Here is where I got the list from:
http://dogbytecomputer.com/universal-remote-control-code-list.html
