20 Most Recent
Sharp AR-C160 Color Copier Questions & Answers
Error Code
go to service mode then cancel it after that switch it off for 5 seconds then turn the machine on again
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
SHARP MX350N . ERROR CODE H4-01
You might Google the manufacturer and the error code to find a solution. If you have an owners manual, I would check there first to find how to solve the problem. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. You also might also enter the "menu" on the printer if there is one, and discover whether you can solve the problem there.This is just a shot in the dark and and I would try the owner's manual first, but after all other options have failed, and if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings which might solve the problem. You will loose any settings and any work in progress. Just a guess. Good luck.
Copier problem - service code F1-70
F1-70 is communication trouble between the machine and the sorter finisher. Check the cables connecting the copier and the finisher and power off and on machine. Should clear the code. If problem persists, may need a new board.
I would also check the ground between the copier and finisher.
Don't forget to rate your answers, please!
We have a sharp AR
H5-01. 5 Continuous POUT not-reached error
perform the following procedure to enter the simulation mode.
#-interrupt-c-interrupt-14-ready key
H5-01 code comes on when I turn the machine on.
This code means that you had 3 or more jams at the heat rollers that weren't removed. The machine had to protect itself and locked you out because more paper jams in this area will cause damage to the fuser unit. Inspect and remove the paper jams. Press these 4 buttons within 4 seconds P * C * it will ask for simulation number, enter 14 and press the black and white copy button, follow on screen instructions. if i remember it says execute and the copier will restart.........you may have to press the CA key to exit simulation mode.
Where is the hd
Attached to the main board in a metal box accessible from a panel in the back of the printer.
