20 Most Recent
Sharp AL 1215 Black and White Copier Questions & Answers
The copier makes a loud
This appears to be a gear related problem. To begin with, please check the toner cartridge if its spilling toner. If it is, then the waste toner box is full and needs to be emptied. On the spring lever you will see a small hole, then open it and empty the waste. If need be, unscrew the two screws and completely empty it and the noise will be gone.
I have a Sharp al 1010 that is always indicating
if you have replaced the toner unit the main cpu is bad not realLY worth fixing but this is a very good copier you can get them on ebay , this the only copier you can refilll the toner unit for $6 & DRUM FOR $15 get a AL1655 best deal
STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
Sf-1118
does the same occur when the manual paper feed path is used?
Sharp sf-7100 / status code
H4 means the fuser can't heat up. The fuser lamp probably burned out. Sorry, nothing can be done without tools and new lamp
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Sf 7800 sharp copier
-Did you try to replace the Toner Cartridge? if not try to replace and installed properly.
or check the Toner Cartridge if installed properly.
