20 Most Recent Sharp AR-275 Copier Questions & Answers
5answers
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
7/2/2021 8:06:25 AM • Sharp AR-275... • Answered on Jul 02, 2021
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
2/4/2021 2:37:13 PM • Sharp AR-275... • Answered on Feb 04, 2021
"TONER REPLENISHMENT IN PROGRESS
please remove the waste toner stored in the waste toner content box
12/11/2018 7:43:32 AM • Sharp AR-275... • Answered on Dec 11, 2018
2answers
Have error code e7-80 on
Usually E7 errors have to do with the scanner or the optics. You should get a hold of a technician to see what can be done to fix it.
9/7/2018 10:45:22 PM • Sharp AR-275... • Answered on Sep 07, 2018
2answers
MY SHARP AR275 SHOWS
Have you replaced the toner cartridge?
10/3/2017 4:13:42 PM • Sharp AR-275... • Answered on Oct 03, 2017
ERROR L4-01
What you have is a main motor lock. Check to see if you have anything blocking the movement of the drum, it could be anything from a staple, a jammed sheet of paper, or a broken drum separation pawl. If you have already removed something from the drum area do a SIMM 14-01 to clear the code.
There also could be trouble with the main motor itself. Check the motor by using SIMM 6-1 to see if the motor turns. If not, check the harness connection between the main motor and the PCU PWB. You may need to replace the main motor, the harness or the PCU PWB.
9/4/2017 1:34:51 PM • Sharp AR-275... • Answered on Sep 04, 2017
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
can be the main motor locked if its l4-01 but if its l4-31 its fusing fan locked detected or l4-35 its PS fan locked detected
9/20/2016 1:35:40 PM • Sharp AR-275... • Answered on Sep 20, 2016
Rulling line in my photocopy document
hi try to print if the line are the then you need to change the drum and the clean blade
10/16/2015 12:49:39 PM • Sharp AR-275... • Answered on Oct 16, 2015
3answers
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
4/10/2015 7:47:52 PM • Sharp AR-275... • Answered on Apr 10, 2015
Sharp error code l4-01
Main motor Lock, check Main Drive , and resistance contributed by all other applicable units
11/4/2014 9:50:10 AM • Sharp AR-275... • Answered on Nov 04, 2014
Where is the thermistor located
on the upper heater roller surface f
8/17/2014 1:35:12 AM • Sharp AR-275... • Answered on Aug 17, 2014
0answers
2answers
Do I need to input code after chenge new toner?
http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/MFPsPrinters/Manuals/cop_man_ar235_75.pdf Go to page 82 for instructions, no code is needed to be inputted after changing toner.
5/13/2014 6:04:42 AM • Sharp AR-275... • Answered on May 13, 2014
0answers
Service F1-15
Your finisher lift motor is not functionning well,just check it?
1/7/2014 4:13:18 PM • Sharp AR-275... • Answered on Jan 07, 2014
U2-40 error
Replace the CRUM chip/CRUM chip defect
10/24/2013 10:25:01 AM • Sharp AR-275... • Answered on Oct 24, 2013
Sharp AR-275 Copier Logo
87 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp ar 275 problem e1 15 error after
  • Office Equipment & Supplies
