20 Most Recent Sharp AR-M237 Copier Questions & Answers
Error code F6-10 on Sharp AR-M236 how do i remedy
This indicates to me that there is a Fax module fitted to your machine. If this is the case it may have developed a fault. Do you use the fax? If not you could try removing it so that you can use your copier as normal. Good luck Follow me on Twitter @CDOS_Service
9/12/2019 8:19:19 PM • Sharp AR-M237... • Answered on Sep 12, 2019
4answers
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
7/2/2019 6:20:43 AM • Sharp AR-M237... • Answered on Jul 02, 2019
ERROR CODE E7-03
E7-03 indicates hard drive trouble. the hard drive is going bad. There is not a whole lot you can do besides trying to reseat all connectors for the hard drive (the harness/wire from the HDD to the ICU PWB board) otherwise replace the hard drive.
4/29/2019 12:08:49 PM • Sharp AR-M237... • Answered on Apr 29, 2019
3answers
Please i need to reset my sharp ar-m236 password
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
10/24/2018 12:20:49 PM • Sharp AR-M237... • Answered on Oct 24, 2018
5answers
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
6/25/2018 9:43:34 AM • Sharp AR-M237... • Answered on Jun 25, 2018
0answers
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
9/16/2017 7:49:53 AM • Sharp AR-M237... • Answered on Sep 16, 2017
It says to close the finisher unit and finisher
We fixed this by taking the finishing unit (tower to the left) and leaning against it so it had better contact with the rest the copier
1/20/2017 11:18:13 PM • Sharp AR-M237... • Answered on Jan 20, 2017
Why sharp ar 287 undertone
mite need a need anew drum. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/13/2016 12:58:02 AM • Sharp AR-M237... • Answered on Mar 13, 2016
2answers
F2-02with sharp ar-275
Toner supply abnormality check toner motor and DV mag sensor
1/28/2016 3:49:39 PM • Sharp AR-M237... • Answered on Jan 28, 2016
I have a service code
H3 00 Heat roller high temperature detection
4/27/2015 5:11:30 PM • Sharp AR-M237... • Answered on Apr 27, 2015
2answers
Sharp ar-m237 default username and password
admin
Sharp
2/9/2015 10:50:34 PM • Sharp AR-M237... • Answered on Feb 09, 2015
SHARP AR-M207 displaying an optional fax kit is not installed. what should i do?
is there one in the machine. does it have the phone cord hook up on the side of the machine if not you do not have the fax capability, it was an option on this model. you would have a hard time finding one now. if it is there the fax board is damaged and would need to be replaced but like i said you would have a hard time finding one.
10/6/2014 2:55:52 PM • Sharp AR-M237... • Answered on Oct 06, 2014
WHAT DOSE F2 MEAN
most of the time it is the chip on your toner cart. you need a new toner cart.
7/29/2014 12:55:38 PM • Sharp AR-M237... • Answered on Jul 29, 2014
Get a misfeed has occurred but there is no missfeed
Your paper may not be feeding, try your bypass tray. If that works you may need new feed tires for your cassette.
7/9/2014 12:33:34 AM • Sharp AR-M237... • Answered on Jul 09, 2014
2answers
What is the solution of sharp showing f2-40
toner problem, remove toner restart copier and reinstall toner. If that doesn't work you may need a new toner.
7/9/2014 12:28:39 AM • Sharp AR-M237... • Answered on Jul 09, 2014
En la fotocopia dora me
Hola buenas tardes, me podrian ayudar tengo una copiadora sharp ar m237 y me esta marcando el codigo U2-40 y no se que hacer alguien pude hacesorarme
7/3/2014 8:57:59 PM • Sharp AR-M237... • Answered on Jul 03, 2014
How to change password sharp 236
Log to admin setttting and change,
6/27/2014 4:53:21 PM • Sharp AR-M237... • Answered on Jun 27, 2014
0answers
Sharp AR-M237 Copier Logo
223 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
says close finisher unit finisher
  • Office Equipment & Supplies
