20 Most Recent
SharpVision XV-Z9000 Multimedia Projector Questions & Answers
I changed the bulb and still the two red indicator
Unfortunately, the "two red light" problem appears to be common to Sharp and Eiki projectors (some models use the same circuitry). Your projector will need the power supply and/or ballast replaced by a technician. From what I've seen, that can run several hundred dollars.
I just replaced the bulb
According to the manual, the problem is with the lamp circuit, what technicians call the ballast. It's not a user-replaceable part. Send it to a service center or look for a replacement unit.
I followed the above directions
check this picture
At the back of your projector just right beside the blue VGA cable, there is a tiny hole in between the HDMI cable. That is the reset button where the red pointed arrow displays. Just turn off your projector, then press and hold that for 4 secs. That is how you will reset the projector
I habe a Sharp SharpVision
If you are using it for a long period of time, try to have it rest for 2-4 hours. But since you just watch a movie and it did not work on another, I guess those 2 red lights indicating that you might have trouble with the power supply of it or its battery. You may unplug, hold the power button and replug it to check if the system can work. If it is no good, then have it repaired by calling your dealer..
Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Broken lamp on Sharp XV Z9000 and projector not switching on
if the lamp blew during use, the projector was not able to complete the shut down mode. it will turn on by itself until it does. replace the lamp, let it warm up, and press power to initiate the shut down. after it powers down, reset the lamp timer and turn it on. all should be well.
VGA video display
Can you describe what you mean by the display not being right? Are the colors wrong or does it not display at all?
Thanks,
Dan
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
